- Jun 8, 2008
I have had my small sebenza 21 for around 7 years. After all this time the lock bar travels all the way across. About 90-95%. What can I do to fix it? Will crk fix it?
Please pardon my off topic comment, but the title of this thread would make a good band name. The Traveling Lockbars..![]()
You might wanna try the early lockup trick. I can't remember where I learned it, but it's worked for me a few times.
My newest sebenza had over 90 percent lockup out of box, and I brought it back to ~80 by doing this. With other knives, it's worked even better.
Here's what you do:
- slightly loosen all of the screws on the non locking side
-Push up on the butt of the lock-side slab with your thumb, and down on the top (pivot side) of the non locking-side slab.
- while holding it in this position, tighten all of the screws down starting from the back and ending with the pivot screw. Don't be afraid to crank down on them
-release your grip and then open and close it a few times. Should have earlier lockup now, and it should stay that way.
I saw JDavis post that on you tube, basically skewing the parts to get a earlier lockup, no thanks.
Is it skewing, or realigning the parts?The tolerences are so tight can it be skewed? And if it is being skewed how much? Can racking the frame a .001 of an inch change the 3 main parts of the knife to the point of being dangerous?
I don't know how dangerous it would be but if things are not aligned properly wear occurs, it is simply not needed. Chris purposefully makes him knives with late lock up, because he knows what he is doing. All I am saying is that I would not recommend it.
