Treadmill motor?
Used my treadmill to hang hunting clothes and fishin vests on for a few years. Finally torn the whole thing up into smaller pieces for easier storage and discovered this 1.5 HP DC motor. Before I venture down the obvious path, has anybody tried to use one of these? I was thinking about driving a 12" Disk. Thanks for any wisdom you may impart. Terry
Yes, a number of knifemakers use them. They are usually open motors, so you have to be careful to keep metal dust blown out, Bruce Evans uses womens hose,I believe, stretched over the motor openings, as an air filter.
I believe he has been using his for a couple of years.
Good luck to you, you will enjoy variable speed. :)
No they are no good so go a head an send it to me:D
Yes I had one,love it untill the controler went out.
Thanks for the notes, I will give it a try. don't suppose the little woman will wonder what happened to her pany hose. T:D
Thought I posted here last night,but I didn't get it posted intime before they shut down and forgot to get back to you..
Yes I have been using one on my grinder and one on my metal cutting bandsaw for a couple of years now,they work great..
I had some trouble with the circuit board on one and found that a couple of the conetiond on the board had come loose so I re-soldered them and have no more trouble..I also found that they work better for grinding and cutting if you will btpass the in line fuse.Mine were making the motor and board over heat and also kept blowing the fuse,since eliminating this I also have had no more trouble.They don't want to be dogged on real hard so keep this in mind when grinding..I have quit using the pantyhose over the ends also,I just keep it blown out and have been running it this way for over a year like this with no problems..The shaft is metric so you may need to check this before ordering your disk or else find a shim to fit it and the disk ..
You will love it as a variable speed grinder motor if you dont have one already or never used a variable speed grinder before..
Good Luck,
Bruce
Nope George..Summer is here and they are not worn as much:D :D :D Donna has been keeping here legs tanned so nice that she doesn't wear her Thigh Highs as much anymore...Bummer they look so good on her to..:p
Bruce
Thanks Bruce,it will be a bit before I can try this but sure will. My new shop is built, working on the work benches and cabinets now. Just have to take time out for a little knee surgery:mad: , then I can get back to it. Thanks again. I will let you know how this works. Terry
