- Feb 4, 1999
What a mess! My grinder is on the way, and that left me with trying to figure out motors. If you're like me and you buy tools that plug into the wall and you generally have never needed to do any wiring or electrical work, buying a grinder without a motor is a bit of a shocker (no pun intended). I have a patient who hooked me up with a 2HP motor for cheap and I thought "Great!" Until I found out that everything over 1.5HP requires a 220V outlet and circuit (like your dryer probably). Then I found out I have no extra spaces in my panel for a 220V circuit, but to have an electrician fiddle around with options and install an outlet would be at least $150, probably more like $200, and that's only IF he doesn't have to install a subpanel, etc. Sheesh!
So, I downgraded my motor at the same shop to a 1HP
but then found out it has a 7/8" arbor, so the pulleys I ordered won't work and I needed to order a special one from Rob Frink. Now I have to figure out how to attach the wires on the motor to a power cord and make it run CCW. The guy at the shop said "it's color coded. If you can put a puzzle together you can do this" but somehow I don't believe him.
So, anyway, grinder is on the way, belts are on the way, pulley is on the way, motor needs to be picked up and screwed with by me... Better all be worth it!
FYI, if you find yourself in my position and considering electrical stuff, don't even bother looking into it. Call an electrician and save yourself the hassle. It's probably a good idea to have 220 coming into your shop at some point, anyway, because mills, lathes and most of your decent size motors will all require it, but unless you're an electrician I wouldn't screw with it. I took one look at the tangle of wires in my packed panel in the basement and ran out there screaming like a little girl!
