- Sep 19, 2001
using this applet, http://www.carbidedepot.com/formulas-trigright.asp , I stuck some numbers in just to give me something to think about with angles and blade thickness. Thinking in millimeters and microns is best, imo, since it's simply 1000 micron = 1 mm, so thinking in terms of either relief or microbevel is easy.
for a height of 1 unit, width is roughly (degrees per side)
0.246 at 7[SIZE=-1]°
0.353 at 10[/SIZE][SIZE=-1]°
0.425 at 12[/SIZE][SIZE=-1]°[/SIZE]
0.536 at 1[SIZE=-1]5°
0.611 at 17[/SIZE][SIZE=-1]°
0.728 at 20[/SIZE][SIZE=-1]°
[/SIZE][SIZE=-1]0.933 at 25[/SIZE][SIZE=-1]°
1.155 at 30[/SIZE][SIZE=-1]°
[/SIZE][SIZE=-1]I think these are pretty common angles mentioned here, or used in sharpening systems. For me, having something to look at in this regard helps me consider the actual implication of changing sharpening angles. It's obvious that higher angles mean thicker edges, but to see the numbers sometimes makes things a bit more clear.
*waits for someone to ask about convex edges
[/SIZE]
[/SIZE]
