Rather than wonder what happens, I would suggest that you forge 2 blades using the same methods. Then test the two, one with mulitple quench and the single quench. Test for edge flex, temper until each quits chipping. One may need a higher tempering temperature, or they may be the same. If mulitple quench has any influence, the MQ blade may quit chipping at a lower tempering temperature. Then test each of them for cut, compare the results. Finally try a 90 degree flex. One may be tougher than the other. If they both pass the 90 degree flex, try 180 the other way and back and forth until they both fail. Be sure and mark the tangs so you know which is which.
When I started experimenting, I tested many blades. The first year I forged blades, I did not complete one, tested them all! One of the most significant aspects of the multiple quench is use Texaco Type A. or an exact eauivalent. If there is one.
Most failures of forged blades can be laid to one of three major variables.
1) Poor steel
2) Forging too hot
3) Using the wrong quenching oil.
There are others, too hot before quenching, oil too hot or cold. You have the ability and everything you need to determine what works for your steel. Keep complete notes! Let us know your results.
