- Sep 10, 2010
I've been using the 3M Trizact CF belts for years and have been using them incorrectly the entire time. Trizact CF belts are delicate, structured abrasives and are meant to be used with minimal pressure
My typical grit progression is 3M Ceramic 50, 120, and then Trizacts 100A, 45A, and sometimes 30A.
When using Ceramic belts, I'm a heavy pressure style grinder. This style is compatible with ceramics which stay sharp through fracturing. Heavy pressure keeps the belts cutting hard and long and creates clean lines. This heavy style quickly becomes muscle memory as you spend dozens of passes hogging off material creating the bevels.
No idea how I didn't realize it, but I've been applying that heavy pressure, muscle memory encoded approach when I switch to the Trizacts. DOH. This has often left my blades with a smeary, uneven finish as the tracks on the belt clog up and get destroyed by the pressure.
I recently started using very light passes and my surface finishes have improved drastically and the belts are lasting much longer. With light pressure, even an A100 finish on 3V looks nice. A 30A finish is dead sexy.
Just thought I would put this out there.
