The reason for the doubt is:
D2 needs to be placed in a foil packet, slowly heated to 1500F, then raised to 1850F and held in the kiln/oven for 15-20 minutes at 1850F. Then the blade is removed and either plate cooled, air cooled. After the cooling, it is tempered at 400-1000F, depending on the use .
Did you read something online that made you think you could open heat it in a forge? A lot of bad info is on the web. Getting a HT book will solve many issues, and answer very many questions.
The directions posted on charts or spec sheets for stainless steels assume that the reader has the knowledge to do a stainless HT. They seldom say to wrap the steel in a foil packet, or to use a HT oven for instance. The instructions usually just give heating rates, rest points, austinitization ranges, soak times, and tempering range. It is up to the individual smith to do his learning first by reading up on the subject. The introductory chapters of most HT books are filled with boring metallurgy...but that is where they tell you these things.
A thought just occurred to me.....
Are you sure it is D-2?
