Blue Sky
- Jun 16, 2002
This is a tip I'd like to share for all the trollers out there that don't use downriggers, dipsies or jet divers. I found it long ago and unfortunately no longer remember the original source, though I would like to give proper credit if I could:
I used this technique a lot on Lake Erie with three-ways and/or trolling sinkers for walleye and smallmouth, it does work. If you ever read the book "Precision Trolling" you'll learn how weight-only trolling depth control is so very speed-dependent. This technique takes the speed element out of the equation and is pretty consistent.
"The rule of thumb that you need to follow is get to the speed that you want to troll and freespool your bait to the bottom. When your weight gets to the bottom, put your thumb on the spool and hold it for 30 seconds then repeat that process two more times. After three cycles of dropping and waiting 30 seconds, you'll be running about 2 feet off the bottom. That works no matter how fast you are going."
