Included would be the total angle, so 7.5 degrees per side. Yes this sounds very low, but mainly because of the myth that 22 degrees per side is needed for general utility knives. This probably came out of the use of ultra brittle stainless steels for heavy use knives. Many of the current popular cutlery stainess steels have toughness many times to one lower than the tool, spring and carbon steels they replaced and far lower ductility levels as well as much more coarse grain structures.
On the wood cutters I use none of which are stainless steels (or high alloy steels), 15 degrees per side is where I generally set the lower end blades, machetes and the like. At this level they will handle all manner of woods well, and will take at most very slight damage on hard knots, dents like 0.010" thick at the back. High end knives made of better steel can take lower edge angles still :
http://www.bladeforums.com/forums/showthread.php?s=&threadid=215025
This isn't light tappy chopping either, it is full powered swings using shoulder drived swings, penetration will be 2"+ on clear pine.
If chopping isn't a requirement the edge angle can be set very low. My regular utility knives are set as low as I can grind them, generally from 5-10 degrees per side, so 10 to 20 degrees included. The notion that edge holding decreases as edge angle decreases is also a myth. It will increase many times over as long as the level of functional durability isn't lost, and for the majority of tasks this is very low. Consider just how soft most materials are compared to steel.
This isn't to say that 22 degree bevels or even more obtuse ones are not functional. I usually carry one knife with such a high edge angle which gets used to cut very hard materials or soft materials that are on hard materials, do scraping, edge prying etc. . I also usually microbevel the edges on my knives for ease of sharpening which does make the very edges significantly more obtuse, however this only extends to a depth of microns .
-Cliff
