True SPEARPOINT fixed blades?
Sid Post
Basic Member
After two days at Texas Blade, my search for a Lambfoot Sheffield-style slip-joint and Spearpoint fixed blade was unsuccessful. 😕
Googling and some general forum searches turn up mostly daggers but, nothing in a more classically styled spearpoint. Who makes good production quality spearpoint fixed blades in a ~5" blade length? I'm looking for a user so, any of the common stainless steels seem like a good option with a Kydex sheath as general guidelines. I specifically want to avoid needle tip 'dagger' profiles and want a spearpoint with a little bit of 'belly'.
Who makes them? Where should I be looking?
It seems, to me anyway, that the definition of spear point varies a little from person to person. So, my suggestion may not be something that you are looking for. For spear point, I like the old classic Kephart style knives. I don’t own any of the newer renditions yet, but I plan to sooner than later. Personally I like the looks of the LT Wright, Becker, and Carothers versions. Good luck on your hunt!
Hinderer (search for Ranch - comes as Bowie, Spearpoint or Harpoon, with 3V or O1, leather or Kydex)
Above are listed as spearpoint and fixed .
May I suggest getting a custom made? I’m unsure what the price would be for what you want, but I feel like you should be able to find a good maker here or elsewhere who would do it reasonably. That way you could get exactly what you wanted.
what about something like this?
That one is in the right direction but, I would like a little more belly and it looks like it is pretty flat so, I don't think it would hold up well in a hard stab. Of course, depending on the steel, hardness, and the stock thickness could all affect that.
Good points!
Ideally, I would like something constructed similar to a classic dagger with the strong center 'rib/spine' and four flat ground sides instead of the flutes without the needlepoint tip and a classical general belly to the tip.
What about the Joker botero?
