The easiest thing to do if its not really really bad ( to the point of needing reground)is to work on it with a good set of bench stones. Start out with a coarse stone. Soft arkansas would work if you can't find a coarser oil stone, or somewhere around 220 grit diamond stones. Just work the edge over giving each side the same number of passes. It will take a while, switch from one side to the other about every 3 to 5 passes to keep things even. Do that until the edge bevel is completely restored ot how you want it. Then switch to a fine stone (hard arkansas ,600 grit diamond) and do the same routine of giving an equal number of passes to each side. I don't know how sharp you want it. You can go even finer, the main thing is to do the same amount of work on both sides. It will take a while, but the results should be good. Grinding might go a little faster but you would still have to go through resharpening it the same way, and its harder to keep it balanced when your dealing with such a thin edge. Not to mention the trouble of keeping the blade cool enough that you don't ruin the temper.
Hope that helps.
Fix it right the first time, use Baling Wire !
