- Feb 25, 2006
I am trying to drill lightening holes through the Stainless Steel liners on my RAT 2 CF. What kind of drill bits do I need I can not get any thing to go through.
This ^Its hardened so you need a drill bit for metal. Use a punch and Start with a small bit. Then go to the size you want. Use a little oil and go slow.
Except that you simple can not drill hardened steel with ordinary HSS or HSS-cobalt dril bits .............OK here are some photos :
The sheet metal strip with the same size round holds we will call "The Work" which is your liner.
I have a strip of aluminum in the photo because it was lying around and handy.
In any case you will want to start with a very small drill bit on the order of 1/16 (1.5mm) to easily get through the plate. Then maybe a bit in-between that and the 1/4.
Don't try to force the Unibit through the plate without a hole drilled with the smaller bits.
The tiny bits you can turn faster like 600 or even faster but the larger bits much slower so they don't heat up from the stainless steel.
If using a drill press :
Some of this you may want to apply / make due when using your hand held drill. It will be much safer that way.
The Good Solid Stop will keep the work from whizzing around like a propeller and knocking the crap out of you.
The Optional Hold Down is optional with the UniBits but is a MUST if you try to drill the liner with normal spiral bits because the bit will screw into the work and lift the liner off the table (off the backing plate).
These are various sizes and styles of UniBits.
Google Artu drill bits, i've used them to drill full hard M2 steel without problems.
You absolutely need a drill press though, freehanding will not work.
This one will drill through any steel , regardless of hardness .I guarantee youI am trying to drill lightening holes through the Stainless Steel liners on my RAT 2 CF. What kind of drill bits do I need I can not get any thing to go through.
