- Sep 7, 2016
I hope you laugh when you see what I did there.
I have completely caught the Busse fever and its about time to get a WE and start sharpening soon. I still have some partially unanswered questions. I have done lots and lots of looking around, and just need some more recent updated opinions and any scientific results anyone has.
I would like to know what the lowest blade angle that can be used before damage is most likely to occur to any of the Busse steels or any of the other steels I mention if you care to help. I know it helps to understand where I am coming from so I will explain the best I can.
For INFI, SR101 on a Medium to large or even larger blade knife, at what degree per side (DPS) or inclusive angle would/ should be the lowest degree sharpened to: to reasonably chop wood and not experience "out of the ordinary damage, from out of the ordinary use in this manner?" What would be that same angle for everything EXCEPT hard wood?
For elmax on blades 4 inches or less, what DPS or inclusive angle would/should be the lowest for a slicer, where green vegetation or skinnng game, would be the hardest reasonable use for this steel/knife?
Same question for medium and up knives in top of the line 1095.
For premium steel folders: My goal would be normal EDC where I do not use and abuse and really appreciate slicers but there is the occasional harder thing to cut, like cardboard or something else unpredictable in EDC that can potentially harm the blade.
So what would your blade angles be in that scenario for: aus8, 154 cm, VG-10, s30v, s90v, s110v?
I understand there is a bit of a sliding scale here. I know there are always exceptions to the rule but I am looking for the typical threshold that grants the best edge a knife can have without compromising its integrity. I have a pretty good understanding but there doesnt seem to be much recent information on all of these steels with difinitive answers as can be, for such a subjective topic. I also understand that mico-beveling can and will strengthen the edge geometry for a stronger edge. At the moment I prefer not to micro bevel unless I need to. I feel like if I know the lowest DPS or inclusive angle that will sustain normal use, then there is no need to micro bevel unless the blade is thick and needs relief for better all around use.
Thank you in advace.
