Hi all,
I have the TSProf K03 and am looking to see if anyone has need to use more then the 22 deg standard body. I am thinking about getting the Extended Angle Height Adjuster which extends the sharpening angle of up to 36° per side. So far I have not needed the additional height angle.
So the question is do I need the extended angle height adjuster or is the standard 22 deg good for all needs. Has anyone needed the additional angles from 22 - 36 deg?
I also want to get the Universal Convex attachment 4.3, 7.2, 10.7 radius adapter. I was thinking about changing the angle of some of my knives for extending the use before needing to be sharpened.
Is the plastic case worth the money?
Thanks Rich
I have the the following
TSProf K03 starter kit
Small universal table (for scissors) and works great
Whole milled clamps set
Whole milled fillet clamp set
Single fillet clamp
Single clamp
5- Hex head drivers
Custom made Oak base
Digital angle gauge
Venev Orion Diamond F60
Silicone Carbide stones: 120, 240, 600, 1000 ,2500, grit (JIS)
Breeze 4000 grit (JIS)
Thanks Rich
Single fillet clamp
Single clamp
5- Hex head drivers
Digital angle gauge
