The K03 Stone holder holds the dual sided Venev stones very well and perfectly secure. I've had no issues at all with how it clamps them.
Regarding your point about the single sided stones up to 4000 grit - you are talking about the Edge Pro Matrix stones here; they go up to 4000 grit.(Which is about 5-6 micron size diamond particles). But make sure to read on...
The Venev single sided stones go up to Fepa-F 1200 (2-3 micron size diamond particles). Single sided and dual sided Venev stones are the exact same grit ratings, there is no Venev 4000, only a Edge Pro Matrix 4000.
Be careful to compare apples with apples here, because the grit ratings used is vastly different with different stone brands. This is a mistake many people make when comparing "grits with grits".
Venev uses the Fepa-F grit rating, and they also list the average diamond particle size for completeness. The Venev 1200 is a much finer stone than the EP Matrix 4000. As an example, if you would compare Fepa-F 1200 grit to Japanese JIS rating, then it would equate to about 5000+ grit JIS.
As a matter of interest, some background info if you are interested - Venev offered a 2000 grit (Fepa-F) diamond stone for a while, which is around 1 micron diamond particle size. (That would equate to about the same as a Japanese Shapton 16k in particle size). They found that the "binder" actually caused a scratch pattern coarser than the actual diamond particles, so they replaced most of their finer grit stones (400 and up) with a new binder a year or two back. They call it "OCB" binder. It works a lot better with the finer grits. Unfortunately, they still found that in their 2000 grit stone, the diamonds clumped together and caused scratch patterns equal to lower grits. Because of this, they are not really offering the 2000 grit any more.....but honestly the 1200 leaves a killer finish already. If you want to take it higher from there, then loaded strops are the way to go.
