Richard338
- May 3, 2005
My katana blade is on its way back from Peters so I started making the Tsuka (handle) core.
I have three pieces of terotuf stacked to make the core. The outer two layers are 1/4" and the inner layer matches the 3/16" blade thickness (total of 11/16" right now). I left a bit of extra around the profile until I get it inletted and glued and bolted together.
I'm attempting a "haichi" shape which is narrower (in width) in the middle by flattening on the "ha" blade edge side and following the curve of the blade on the "mune" spine side.
I've noticed that some first attempts seem to end up with a larger than desired handle, so I'm trying to avoid this. I also need to allow for the rayskin and ito wrap with menuki which will only make it thicker...
Does anyone know if the core is typically made thinner in the middle as well as narrower?
Anyone know any typical dimensions?
I made it 10" long and it is designed to fit into oval fuchi (collar) and kashira (butt-cap) that are 1.6" on the long axis.
Thanks for any input.
