Tuf-Glide caused my Leek to not open all the way?
So I just got a Kershaw Rainbow Leek and I put some Tuf Glide on the pivot and blade to prevent corrosion in storage, and now when I hit the flipper it opens mostly but not all the way into a locked open position, it was opening fine when I first got it.
Is there a fix for this by chance?
So in taking it apart I noticed the dirt was mixed in with the grease, so that has to go but does the spring need to swim in grease or can oil or tuf glide do the job for that too?
No. It's important to let the tuff glide dry and use it sparingly. Oil should be used sparingly too. If not it attracts dust and lint.
Is there a dry way to do that, like say one that does not attract dirt, grime, and is not completely disgusting?
I really hate grease.
If you want to get all DIY on it. :D
Grease recipe #1: modern kitchen style
Ingredients: 1 bar of plain bath soap, 1/2 cup vegetable oil
1. Grate soap with a cheese grater over wax paper.
2. Heat 1/4 cup of the vegetable oil in a small saucepan over low heat.
3. Slowly add soap shavings while stirring.
4. Add remainder of oil and/or soap until a you reach a creamy consistency.
Grease recipe #2: ye olde style
Ingredients: bear fat, white wood ash
1. Sift ash into cold water. Let sit overnight, then strain through a cheesecloth, saving the potash water.
2. Render bear fat in a kettle over medium heat.
3. Boil a quantity of the potash water and rendered bear fat while stirring constantly.
4. The mixture will react. Continue adding potash and rendered fat until you have a suitable quantity of soap. Ensure there is no excess lye by tasting the soap. If it tastes sharply of the potash water, add more fat and stir some more.
5. Remove from heat and ensure saponification has halted. Pour into molds or suitable containers before it solidifies.
6. Reheat a portion of rendered bear fat and add grated soap, as in recipe #1.
you could use dielectric silicone grease or take the torsion spring out and de-assist it or learn to love the rattle.
OP: Welcome to the learning curve. Unless you spend hundreds of dollars (and even then it is a c--p shoot), one takes apart new folders when received. And they are cleaned. I am trying glide - tuff and it works better in the last few days then any oil based or silicon lubricant I have used in the past. I just don't know how long the lubricant will last on the pivot point and wonder if you ever researched the area.
Tuf-Glide needs to dry to do its job properly. If you doused it so much that it's swimming in it, then it can attract junk and actually slow things down. When dry, it won't attract dust/lint.
