Erkfsn,
You'll get alot of opinions here regarding these products. To really get to the meat of the matter, you need to tell us what you wnat these products for....ie, do you want rust prevention, lubrication, long term storage, etc.
My feelings are that for most modern folders, rust prevention is the main concern, not lubrication. Most modern folders have self lubricatiting blade washers and/or pivot bushings that the blades rotate on. Additional lubrication can sometimes cause problems, like attracting and holding dirt and grit in the 'action' of the knife. What these knives do need is dry rust preventation in the inner working of the knife, ie the pivot areas. Tuf-Glide is my pick for this. I have had EXCELLENT results with Tuf-Glide and Tuf-Cloth for rust prevention. It has some lubrications qualities, but is primarily a dry, rust preventative.
I will admit not having any experience with Militech, because after learning that it contained CHLORINE, which is corrosive to steel, I have steered clear. It may only attack the base metal on a small level, but I would rather not have this happen long term. I know there are many fans of the stuff, and it obivously must work for them, but since I have had excellent results with Sentry Solutions Products, I have stuck with what I know works. Have the MILITECH users out there had any problems with corrosive pitting in the pvots they have applied MILITECH to long term?
If you are looking for products offering alot of lubrication, like for firearms, Sentry's other products, like Hi-slip grease,Smooth Cote and BP 2000 powder are excellent. I shoot nationally and internationally in clay target competition, and though I shoot an Over and Under shotgun now[needs less maintance, but kicks more], I shot a BERETTA gas operated auto for 4 years. I have NEVER found anything that made a firearm run smooth, cleaner, and longer than the above mentioned Sentry products. A gas operated shotgun is one of the nastiest firearms made, generating alot of gases, powder residue and plastic fouling[from the wad in the shell]. Using Sentry's Smooth Cote/BP2000 combination cut my cleaning from once every 1000 shells, to once every 3000 or more. And when I did have to clean the gun, it was ALOT easier, with residue just brushing off in most cases. If you really want to lube something, give this stuff a try. For most cutlery applications, Tuf-Cloth/TUf-Glide is all you need....IMHO
Stay Sharp!
Will Fennell
Camillus Cutlery
www.camillusknives.com
[This message has been edited by Will Fennell (edited 01-26-2001).]
