Ripper
Thanks.
Any comment for ITC? is the below ok and which would you prefer (I will say them must be resistant to flux):
Also Do i need wool or plastic type of lining or Mortar types are enough.?..
"...GUNNING
REMGUN 60 SIC 10 GG
Mullite based gunning and also castable concrete which contains min. Al2O3 based, SIC addition, resistant to erosion. Many features are hidh strength, high resistance to adhere and erosion.
REMGUN 60 SIC 30 GG
Contains min. %40 Al2O3 and %30 Silicon Carbide; mullite+ silicon carbide based gunning and also castable concrete. Many features are high strength, high resistance to adhere and erosion. Typical applications; against to adhere of dust in cement industry and resistance to chemical erosion.
REMGUN HTG
Remgun HTG is the gunning type of remcast HT, please see Remcast HT for spesial features and typical applications.
REMGUN 60
Fireclay based chemically bonded gunning material recommended for hot or cold durt surfaces. Typical Applications: STEEL-Soaking pit walls, coping, cover and flues, reheating furnace sidewalls, arches, uptakes, noses, open-heart fentails, wing walls, checker chambers.
REMGUN 60 C
Chemically bonded gunning material with superior features. Available both hot and cold surface applications. Typical applications; steel soaking pit walls, coping, cover and flues, reheating furnace sidewalls, arches, uptakes, noses, open-hearth fotails, wing walls, checker chambers.
REMGUN SUPER Lİ
Remgun super Lİ is a an aluminous, hydrauliç setting low iron, gunning castable has good strenght and high resistance to termal shock. Typical Applications: STEEL-polletizing furnaces, hot metal cars, ladles, open hearts fantails, wing walls, soaking pit walls, copings, covers, flues, reheating furnaces sidewalls arches, uptakes, burner walls.
REMGUN 50 Lİ
Remgun 5LI is a specifically formulated hydraulic setting 53% alumina gunmix. It exhibits excellent and abrasion resistance and resistance to carbon monoxide. Initially designed to meet blast furnace stack environment, could be used in incinerator linings, cyclones, gunnite resurfacing of torpedo ladles, soaking pits and reheat furnaces.
REMGUN 70
Contains %65 Alumina and available both hot and cold surface applications. Typical applications; furnace linning and as used covering material.
REMGUN HTG-LI
Bauxite, and alumina based very low iron gunning material. Specifically designed for steel industries severe applications.
REMCAST D-GUNMIX
Gunning type of Remcast D. Chemical resistance to water, acid and gas effects. High strength, hydraullic bonded gunning material with service temperature up to 1316 °C.
REMGUN 80 C
80 % alumina-bauxite based chemically bonded; high erosion and abrasion resistance. Reccommended for; cold or hot high alumina or super duty surfaces. Typical Appalications: ALUMINUM- melting furnace sidewalls below metal line/FOUNDRIES-electric furnaces/STEEL-pelletizing furnaces; hot metal cars; hot metal mixer walls, bottoms and spouts; OSM vessel backup linings (patching); open hearth fantails, wing walls ande checker chambers, soaking pit slag lines and bridgewalls reheating furnace hearths, soaking zone sidewalls and burner walls.
REMGUN 90 C
88 % alumina-corundum based chemically bonded; high erosion and abrasion resistance; low iron; low alkali. Reccommended for; cold or hot high alumina surfaces. Typical Applications; see Remgun 80 C.
REMGUN ARZ
Based on ocean sand, high agregate content and resistance to erosion. Resistance to effect of CO, high resistance to abrasion.Typical applications; high stacks and blast furnaces waste-burning plants, cyclones and heat-traetment furnaces.
