Turn a Mini Mag-lite into a Match Case w/ Compass
At my college I took a machining class a year or so ago and learned how to do basic work on the Lathe and Mill as well as a few other things. I don't know much - but I can be a little dangerous when I want to.
I had two Mag-lites, but only had enough parts to make one work. The insides of one of my Mag-lites were missing - due to little prying fingers around the house.
I found a small button compass that I have had for a while and decided to make something out of the body of the Mag-Lite.
The first thing you need to do is to chuck up the Mag-Lite in the head stock (using brass as a buffer between the jaws of the headstock and the aluminum body so as to not mar it) and part off the Mag Lite Body:
I cut this down further later but this allowed me to get an accurate measurement of how much I needed to take off.
I then chucked up the butt cap, took a little off it, then bored out the center. It normally holds a spare bulb - but I wanted it to hold a little tinder:
It now holds about 1/2 a cotton ball. This is mostly to buffer the matches - but also will be emergency tinder in a pinch:
I then bored out a little of the maglite itself. This was not necessary but I thought I might be able to get another match held in the case:
I then drew up a rough sketch of the cap (not shown) and took measurements so that I knew how much of the body of the Mag-Lite to take off:
With that done - the body of the Mag-Lite and the butt cap (which will be the top cap) was now done. I needed to work on the cap.
I used a piece of scrap material - and turned down the major diameter (to match the outside of the body of the Mag-Lite and then turned down the minor diameter to allow the part to slip into the body of the Mag-Lite:
I touched up my work a little and then bored the top to take the button compass:
I then needed to part off the piece. This shows how much the part of the cap that slides into the body of the Mag-Lite. It extends 0.250 into the body and takes epoxy to hold it in:
Here is the parting tool getting ready to finish off the piece:
cont...
With that done - I fit it for the first time. It was a little sloppy - but the 10 ton epoxy can take up the difference:
Here is the Maglite with the extra pieces and the new end cap:
After getting the parts home and cleaning them up with some wet/dry sandpaper I mixed up some epoxy. I applied some epoxy and slid the cap into the body - I made sure it was properly aligned and then let it sit:
I then glued in the button compass in and after drying the project was complete:
On top is a Mag-Lite fully functional - and the bottom is the new Mag-Light! ;)
It holds 12 matches, a little tinder, and has a basic compass.
TF
Cool idea - I have a busted mini-mag somewhere that I was hoping to make into a fire piston.
Thanks for sharing.
Wow- and I was just going to take the batteries and the bulb out! ;)
A mini-mag light is one of the most ineffective / inefficient lights on the market. You have discovered the best possible use for one! I'm serious, very nice work.
BTW: Fenix lights are a great value etc
CCKW,
I LOVE my two Fenix lights. I like the Maglite for around the house. Doesn't draw much power - and the kids can use it when they want and I don't worry. ;)
TF
