- Aug 26, 2004
This is a more in-depth tutorial than the one I posted before (you can check that one on my website)
I did this some time ago but just now I could manage to get the pics and text done to share with you guys.
I hope you enjoy it!
Cut maple block.
It's very important that the block gets properly squared.
Drawing the first likes for the desired design.
First hole to drill is the draft one.
Then the tobacco chamber one, checking all the time as not to overdrill and go past the draft hole.
As the draft hole gets filled with the waste from the tobacco chamber drilling, I hand check it with a drilling bit.
Then I carefully meassure the diameter of the stem I'm going to use.
Then I make the mortise, that will accomodate the stem's tenon.
Cut maple block.
