- Jul 30, 2006
I carried a Camillus-made Buck 303 daily for over a decade. and loved it. I bought a 1997 Buck-made 303 with flat ground blades a few years ago. Liked that one, too. Recently, I've been carrying a current design Buck 301, and have become enamored of the "edge 2000" modified hollow grind blade design. For my usage, it just cuts better than any other blade profile. But, the 301 is a tad large for some occasions. I decided I needed a new 303. Specifically, I needed one with black Valox covers. The quintessential Buck 303.
Since I mostly hang my hat in Traditional, I have a lot of knives from a lot of manufacturers, so when I got the 303, I found that I wanted to tweak it a bit. I thought the tweaks might be of interest in the Buck Forum. So here I am.
1. Loosen up the blades. The Sheepsfoot was a bit sticky. I had to push it into the open position. I washed the knife in the sink under flowing water with dish soap. I opened and closed the blades repeatedly. Then I rinsed it. First in water, then isopropyl alcohol, then WD-40, then added mineral oil. All blades open and close exactly right. spring strength about a 4 if you rank an SAK as a 5.
2. It had some parts that needed rounded edges. The ends of the springs were not rounded. They were sharp to my fingers. I used a Sharpmaker triangular stone to round them a bit. Now they don't bite.
3. In the closed position, one of the springs was a bit proud of the others. I opened the blade resting on that spring so that the spring edges were exposed, then I used a Sharpmaker stone to slightly round the exposed edge. Now, although the spring is still a bit proud, it is not noticeable unless I focus on it.
All done. Took me about an hour. Love the knife. And I do like it better than the Camillus-made or the '97.
