Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Hi folks, this Christmas I picked up a lovely French knife called Le Trappeur by Chambriards out of Thiers France, it came with a horizontal style sheath, not a bad sheath but they way the people that made the sheath, Max Capdebarthes also in France, they made it so that the leather swells out both sides of the knife, where I usually form the leather so the back side is flat and the raised portion is to the outside. Any ways, their belt loop would just allow an inch and a half size belt, but, when worn, it's VERY tight on the belt and the pressure is also then applied to the knife, being a stag handled knife I think it's thicker than what they normally planned for this sheath, wood scales would probably worked better, but, I like stag
SO, while I could make a new sheath, being busy with many things, time wasn't available right now, and I wanted to carry the knife, as it's very nice. So I came up with an adapter, leather that slides into the belt loop and then folds down to snap into the other end of the leather strip. I made it so the bottom end folds up a little, this way the belt rides against the bottom of that hook of leather and not against the snap, which might cause the snap to unsnap when you didn't want it to. I may try to incorporate this type of thing on some of my vertical sheaths, instead of just a belt loop folded down, I'd have it fold down and then have a smaller bit of leather sewn on the bottom to fold up and have the other piece of snap there. This would make it a lot handier if you wanted or needed to unhook your sheath from your belt but didn't want to undo your belt. Here are some shots of the adapter I made up, works great and allows me to carry this large folder.
And it doesn't make it extend much farther out than before, and as you can see, I made the top section a little longer so you can grab that to unsnap the belt loop. And even if it gets unsnap accidentally, it will still hang on the belt pretty good too.
G2
sorry, edited to add some shots of the knife, well a trio of Chambriards
Here are a couple quick shots, the stag is very nice on all three, Le Trappeur, Le Compagnon, Le Compact
as is the file worked spines
G2
