Twisted
Twisted Grind...
Double chisel grind "Experiment" on a nasty little blade:eek:
Before HT pics it will cut both ways like a lazer when done, may wind up as a future Bali Blade.
Sometimes you need a break from the usual grind!
Contructive Comments welcome
I made a blade with the same grind as that a year ago or so. It warped pretty bad during the heat treat. It is a cool idea though. I would like to see if yours does the same as mine did.
Good luck with the Heat treat. And it looks good.
I like this.
What are the current specs on it (thickness, blade length, OAL, etc.)?
How much for one like that, about 8 inches OAL, satin finish, cord wrapped handle?
Let me see how the HT goes today I will normalize it a few times first then harden it...Wish me luck.
Email me for specs: Blinker123 (at) qwest.net
I like the idea of using it in both directions as needed. My comment would be the handle should be designed to function tip up or down also. Uni-handle could be the term, usable in any direction or gripping method. You've most likely already considered that.
