twitch 2 tinkering
Hi all, I've been peeping around here recently after polishing and restoring my dads collectiong of old knives (Parker, premiere, western, case, ect...) and I came across the SOG's knives and this forum :cool:
well a twitch II fell into my lap and I said bye bye to the old folders for the new cool stuff :p
Twitch II first impresions:
a little weak but aceptible for a slim ECD, nice and sharp, but I still went straight to stromping the edge, now its silly sharp ( had to buy a new box of bandaids)
there was wiggle between the bolster and blade, they slightly over ground the flat grind on the right side of the blade, leaving a mark, wich i think should not have passed quality control, but I guess the knife is not expensive enough to scrap a blade for a slight inacurracy, there is also a little wiggle up and down in the locked open position, i can live with that.
OK I love this knife... its awesome, if SOG could get the precision tolorences higher, i would gladly pay $50 more, the ergonomics are great and the SAT system is wonderfull altho the spring is too weak, I had to go to home Harware to get a stronger spring and tweek a little more tention to get the bolster screw tight enough to eliminate wiggle completely, now the knife felt sturdy but it would not open fully on its own without a flick assist so i dismantled it and water sanded the bolster area with some 2000 grit wet sanding paper...it opened a little more, added some light oil... it opened a little more again(keep in ming the bolter screw is very tight at this point, no sideways wiggle at all just flex due to the slim design).
ok here is where I finaly got the knife to open easily with the very tight bolster, I removed the blade and smeared a little Phil Wood waterproof bearing grease (the green stuff that you can get in most bycicle shops) on both sides of the blades bolster area...I garantee you can get another half turn tighter on the bolster scew with that stuff and your twitch will still open.
Anyhow great knife for the price WTG SOG...I'm twitching to get my hands on the XL in the near future :D
Same here.:D
Sounds like you might be catching the SOG bug too, just make sure that you have a good income to fund your new addiction.:p;)
I see you are new... so welcome to blade forums.:)
thx for the welcome, and yeah...must intercept credit card statments before wife gets her hands on them muhahahaha :D
SCREEM, welcome to the SOG side of BladeForums :D . I know exactly what you mean about the Twitch, silly sharp is a common problem with my SOGs too, usually cuts when you don't expect them to, (I then smile like I know what I'm doing.........) :rolleyes:
I usually break mine in by opening about a couple hundred times or more, then add a drop of oil.
The XL is scary sharp :eek: out of the box, and check out the new Trident folder, it too is a nice knife.
Robbie Roberson ;)
Robbie Roberson ;)
Only a couple hundred !:p
SCREEM, dont listen to him, the proper procedure calls for a couple thousand times.:D;)
Nah, you can trust Robbie's advice, he knows what he is talking about... after all he is the one who invented the incredible SOG Revolver concept.:eek: (I wish I could say that about myself)
thx Robbie
hehehe
I have a blister on my index fro m the blade kick :D
the trident doesn't look to sheeple friendly I'll see how they react to the twitch XL first :D
Socintel is right, but who's counting........ :rolleyes: I like em all !
The Trident is a bigger knife, and the Twitch II is a little cutie :) , so you might consider the Twitch I for your wife :rolleyes: , then you don't have to worry about credit card bills.
Robbie Roberson ;)
Robbie Roberson ;)
yeah, but than you have to worry about getting sliced to ribbons.:eek::D
I got a Twitch II (the Black Ti and gold version) and had to send it back to SOG because the secondary lock did not work. I also have a Twitch XL and a Blink. The blink is the best of the bunch.
Vince.
Yup, The Blink is one great knife. At the moment I am EDCing my blink. (along with my Revolver-H,Powerlock and Flash II. :eek: :D )
