- Feb 16, 2010
Thanks to Dave Breese(Iowashtr), I just got 30 9x4.5x3" firebricks and a box of 2" thick inswool chunks measuring 18" x 16". I want to make a steel framed forge using a couple bricks cut in half and wrapped in wool with a sheet metal and angle iron frame. First, I have a few generic questions:
1. How tight should the inswool be squeezed in there? Should it stay at a loose 2" or press it to 1" nice and tight?
2. What shape should I cut in the firebricks? Round is easiest, but would a flat bottom work better? Square with X-shaped grooves in the bottom to let heat underneath? Triangle with the burner at the top? Upside down mushroom?
3. It's going to be 12" long, can I mount a burner inside or should it just shoot flame from the JTH7 into a hole in the side?
4. Do I need to cement the bricks together or will the wool and frame support it well enough?
5. I plan on mounting my anvil on a 6x6 post in the back yard a few feet from the house. Can I leave the forge outside with a plastic bag over it or will the freeze/thaw of the weather destroy it?
