I made a 2 brick forge this way.
Materials; 2 bricks, some 3/8" allthread rod, slotted uni-strut, 3/8" nuts, 3/8" fender washers.
****Note, I tested this with my MAPP gas torch from my work truck, I DO NOT recommend using a torch directly attached to a gas tank. Buy a torch with a hose and set the tank back from your forge.****
I used my Acetylene B tank and it provided good heat.
Stack the bricks and place strut above and below the bricks. Slide the rod through the slots on one side. the other side will need a 1/4" groove carved in the side as the slots don't line up perfectly. Bolt it all together. Then, I took a 2-1/8" drill bit and drilled to 1" from the back. I added a hole for the torch 1/2 way back on a tangent like a 6 on it's side.
My experience. It worked good for forging. Not as well for heat threat. It was easy to overheat the blade edge and tip. If I did it over, I would drill the torch hole back farther, 2/3's back or so.
I think a freon tank forge would be a much better choice. Buy some refractory cement from Hightemptools, or Wayne Coe, and look up a few tutorials on forge building. You'll be happier in the long run.
Maybe people who have done it can speak better than me, but, I'd guess heat treating a 9" blade(hopefully 1084) would be MUCH easier with an Oxy/Ace torch and a magnet.
If you use a brick forge, be sure to rotate your blade and avoid overheating. I had extra bricks, so I stacked bricks in front of my forge to help it heat up better.
I gave away my 2 bricker, and made a real forge. This is it before it was finished. It's 8" in diameter and 22" long.
