robotech
BANNED
- Feb 22, 2009
Here are my latest attempts are customizing Buck 110's. I have done five like this, and a buck 112.
I like the concept, but hate the weight of the Buck 110. So, I decided to try to make my own lightweight frames and liners for several 110s (and a 112).
So, I ground out some 316 Stainless stock (.030 Marine Stainless. VERY corrosion resistant). While I was at it, I also cut some finger choils in the liners and scales.
I used the blades, lock bars, back spacers, and springs from donor knives. Everything else was custom.
Pivot, pins, screws, clips (when I put one on) scales, and even had to modify the lock bars and back spacers for the deeper finger choils. All hand fitted.
The 1st one has the parts from an Cabella Alaskan Guide. The black blade is S30V. Black canvas Micarta with yellow G-10 liners. No clip.
Black Designer pivot set, black screws. Weight is 3.8oz, down from 7.8oz stock!
Here I am showing the scales after layering.
This one has a satin S30V blade from a BCCI knife. I really swooped the frame in the choils. Pretty radical.
Antique Bone linen Micarta and white G-7 liners. Gorgeous Carmel color and a soft warm effect. Titanium low ride clip that I polished and flamed from a blue to a bronze to accent the scale color out.
Screws are socket head T-8 TORX, pivot a designer set. Weight is 3.6OZ with the clip!
And here are pics of the other Buck 110/112 customs I have done, in review.
Orange G-10, with white G-10 liner, Buck 112
The last ones were cut from 0.36" 316 SS. Slightly thicker liners. Harder to work with, too. Haven't noticed any strength difference with the .030 I used above, but probably not a good idea to go any thinner.
Tree Boa. CPM-154 blade. Toxic green scales with a snake skin effect. Black G-10 liner. TI low ride clip.
Jade Queen. S30V blade from Alaskan Guide. Jade G-10 over a white liner. No clip. Another RADICAL swoop design.
And my 1st attempt at this. I had a broken blade 110. So I ground the stock 420HC blade down and built a custom SS frame. This one is 3/8" smaller than the 110, as I cut the blade down. Slightly larger than a 112. This one has Earth Brown/Coyote brown/Tan G-10 scales. Kinda funky, but it is the 1st.
I have a Spyderco Blackhawk project going. Cutting new liners and shape frame for the Blackhawk blade.
A Spyderco Pingo getting new silkies and a thumb stud.
Two Buck Strider Taranis.
More to come on those.
That's all Folks.
That's all Folks.
