Two different Cree drop-ins for the 6P (or other P60 lamp lights)
Also posted on Candlepowerforums, this is a short writeup of two different Cree LED drop-ins being made for the Surefire 6P, or other lights that can use the P60 lamp (like my frankenlight, ha).
The first is the Solatek unit being sold by LITEmania for $50 shipped in this thread. He quotes the specifications as such:
XR-E P4
Full regulated : 3.7V ~ 12V
700mA load to LED, Circuit 92% Efficiency Max.
And the second is the unmarked unit being sold for $20 by calvinmo28 in this thread. It should be noted that the $20 price was promotional, however, and his next batch will run a few dollars more (I don't think exact price has been decided). He quotes the specifications as such:
CREE XR-E WD-P4XRE (6300K-7300K) LED
700mA to produce 130.6-141.6 Lumens
The first thing to note about these is the size. As seen in the first picture, they are longer than a regular P60 lamp assembly, and both units are identical in dimensional size (note, however, that this is the old Solatek size: they are now shipping slightly shorter).
When installed as they came, a slight gap in the head was visible on some lights. My personal setup is a Z44 bezel on a Lighthound E2C adapter.
LITEmania is now starting to ship the Solatek drop-ins with a slightly shorter reflector to fix the gap issue, but some people have voiced a preference for alternative means of fitting since this will result in a slightly wider hotspot. Namely, the 'shoulder' of these units can be beveled further, which allows the unit to sit deeper into the light, fixing the gap problem.
Personally, I haven't taken any measures to modify my units as the waterproof seal is not compromised by the gap (inner o-rings are still adequately covered) and the aesthetics don't really concern me. Rather, I have just inserted a GITD o-ring into the gap. The result is pretty clean looking and I like using these o-rings anyway.
I have, however, requested one of the new, shorter reflectors from LITEmania. I'm actually most interested in getting it to compare the change in beam profile, rather than fixing the gap. I will post comparison beamshots when I get it.
Fit and finish between the two gives a slight edge to the Solatek, with the unmarked unit having more solder buildup and some tool marks.
The business end looks just the same however, to the point where I actually had to retake photos because once I loaded the first batch on the computer I couldn't tell which was which:
Some electrical contact problems have been noted with both units, particularly in SureFire G2's. I have found that a small bit of aluminum foil to aid in solid body contact really goes a long way, and makes these both run perfectly. I can even run them easily in a G2 without any outer spring just by using some aluminum foil.
LITEmania and calvinmo28's calculations are the same, approximating 2.08 hours run-time on 2x123 for the units, and Quantile provided a test graph showing the Solatek with a little over 2.5 hr runtime to 50% brightness running on AW18650 Li-ion.
Both units are very bright and very white, with a lot of light in the spill, and a tight, bright hotspot. In fact, they are easily the whitest, brightest LED's I have owned, and I am very pleased with performance. I don't have any equipment to test lumens, lux, etc, but hopefully the below beamshots will give you an idea. All assemblies were used on the same set of fresh batteries, in the exact same body, with the same camera settings (as noted on the image).
Also, here are histograms from the images. Not sure if they are really helpful for comparison, but I'm offering them up just in case.
To my eye, the unmarked unit seems slightly brighter than the Solatek, which appears to be confirmed by the histogram. But the unmarked unit also seems to be just the tiniest bit bluer. Either way, I have seen two 'identical' lights from a single manufacturer vary in brightness/hue more than these two units against each other, so I must call their performance equal.
You're almost buying the same thing whether you get LITEmania's Solatek unit or Calvinmo28's unit. The biggest difference is cost, followed by the fact that the Solatek will now be shipping with a shorter reflector to correct for gap. The final difference is fit and finish, but that doesn't matter to me since the actual reflector and performance level is equal.
I really don't think you can go wrong with either unit. I love both of mine and am going to order a couple more from calvinmo28. With great brightness, tint, and run-time, I think these are great drop-ins.
Is the output from these LEDs' regulated?
Yep, fully regulated so long as you are feeding them 3.7V ~ 12V.
Will one of these fit my G2 ?
Yes, it will fit in a G2, with some important points to consider.
First of all, there will be a gap if you order the cheaper unit, but water-tightness is not compromised.
This can be fixed by sanding the assembly, or covered in a lazy way ;-)
Also note that electrical contact will be slightly trickier given the polymer light body. The outer contact spring that comes on the assembly is slightly too large in diameter to work in a G2 like a P60 does.
You can tighten the coil and trim it, so that it makes contact with the battery tube, or again you can take my lazy way out and just use a wrap of foil. It looks ghetto when you open it up, but it functions 100%
Finally, consider that a polymer light body doesn't sink out heat as well as a metal light. This unit runs cooler than the luxeon drop-ins I used to use, but I haven't used the unit in the G2 long enough to comment on longevity/risk of overheating.
All that said, I do have one of the units in a G2, but I don't plan to ever run it for long durations at once: just short illumination.
Wow yeah great post. I just started using my 6P more again, and between that and my E1E I am burning through some batteries...
Good stuff, I am going to have to check that out.
David
Thanks for the good words, guys.
Does anyone offer a drop in for the E2E?
I am not aware of one, but that doesn't mean they aren't out there.
An alternative is to use an EC bezel adapter on your E2E body, and then slap a Z44 bezel on top. This would allow you to use the drop-in, or any other assembly of the same size (like a P60 or P61 lamp).
In fact, that's the exact adapter and bezel I'm using in my first post above :D
I've got it on a Vital Gear body, but it will work just as well on your E2E body.
I realize that's an expensive proposition though :(
I built mine from the ground up so the component cost wasn't as big a deal as re-engineering an already functional light. It's lasted me through three different incarnations (first a 3W luxeon, then a 5W, now cree).
Does anyone know of a drop in for the E1E?
I figure you guys might, and that is what lives in my pocket...
David
ya outta just get a KL1 for the E1, they run a little less than $50 and work well on the E1.
I know I should have gotten a K1 a long time ago, I have just read so much good about cree led's even a couple years ago I have just held off....
David
