Finally heard from where I had the Tyrade on order and they have arrived. Mine will be here on Saturday, if the USPS cooperates that is, and I've already talked to STR about doing me one of the low rider deep carry clips he has designed for the Tyrade. I'm sure this has been posted somewhere and I've probably already read it, but..........according to the specs the blade is somwhere near 3.6" in length, and the total weight is around 6.7 ounces. What I would like to know is; how thick is the blade and how thick are the titanium handles? Thanks!
I find specs on the Tyrade in several places and in all of the descriptions the titanium handles are described as "beefy". From seeing pics of the blade in relationship with the handles, the blade appears to also be "beefy". I'm just curious as to the numbers. I'm guessing somewhere around .150"~ for each.
ALL RIGHT, my low rider STR clip was in the mail box when I got home from work today! To say I was happy is an understatement. I have degreased the new clip and applied some of the 3M Stair Step tape. Not only does the tape make the clip harder to spot, but it also gives your thumb and forefinger a great grip when removing the knife from your pocket. Proceeded to remove the original clip, applied a small drop of blue loctite to each hole, and screwed on the new deep carry clip. TOTAL PERFECTION! The new clip covers the cutout on the framelock so that it will be harder to over extend the lock when unlocking. In that same vein, Kershaw has done a good job with taking out any vertical play there would be when you squeeze the handle. On a lot of framelocks when you squeeze the handle the frame lock will move upwards on the blade tang a fraction which might change the lockup. This happens because of the cut made to allow the frame lock to exist. On the Tyrade, Kershaw has cut the blade tang so that there is a "ledge" on the tang that covers the top of the framelock when it moves over, thus there is absolutely no vertical movement possible............a neat little touch if you ask me, still a neat touch if you don't ask me.But back to the clip. This is exactly what I want in a pocket clip; perfect fit, thin as far as the width of it, it does not stick out like a sore thumb (no insult meant), and it puts the entire knife into my pocket with nothing but the clip showing!!:thumbup::thumbup:
One more thing to cover about the Tyrade. This knife is thin enough to ride very comfortbly in my pocket, but robust enough to take care of any chore I will need a knife to do. Just see the specs I listed in the previous post.
So, I have put the ZT0500 MUDD up for a much deserved rest and have strapped on the Tyrade. Hell yeah, we ready for anything!!:thumbup::thumbup:![]()
