- Mar 3, 2007
On balance which knife stands out as the better of the 2 The Kershaw Tyrade or the ZT 302 Edc, would be the main purpose. Any thoughts would be appreciated on these knives
Thank you Oilman and Vassillli. I truly appreciate your informative feedback.Okay, my impression was, the ASSISTED Actions where the same on both knives?
Please comment on D2 vrs the other steels you mentioned . Why would either be superior as an edge?
otherwise I see not benefit in composite blade other then decorative.
Thanks, Vassili.
Composite blades are basically San Mai type blades in that a Harder Steel is welded to a softer spine to get the best worlds of edge holding and flexibility
I have owned both and preferred the Tyrade but only after converting it to tip up carry. Once I did that, I found it both more practical, and easier to justify in the city to carry for a couple of reasons over the 301 or 302 folder. But looking at the factory knives I see it like this.
The Tyrade:
1 its heavy at 6.5 ounces in weight.
2 its slim for a big knife but the stock clip and CF insert catch the pocket on slide in and out.
3 its not so wide as to cause you to have to pull the knife out of your pocket just to get something deeper down inside your pocket like your car keys. So, although big, its footprint is tolerable.
4 its tank built but the draw back for some is the clip. One way carry for tip down only and the snagging at the one point where the rim of the pocket goes near the top of the clip.
5 the D2 composite blade is attractive and it cuts well. I can't say I saw a lot of diff between it and regular D2 but it did seem to respond better to the Sharpmaker White hones over everyday D2.
6 when the torsion spring finally breaks it will most likely require that you mail it to the company to fix for you since most folks will be at a loss as to how to access the insides of this folder without marring up or permanently damaging the CF insert which must be removed to gain access to the screws. The Jury is still out on how difficult or damaging this task will be.
300 Series Z/T:
1 its heavy at 8 ounces
2 its wide and thick feeling in the pocket with a huge footprint that definitely required extracting the folder to get to anything deeper in your pocket. Once clipped on the pocket it takes up the whole entry way.
3 its got much better grippiness than the Tyrade
4 its equally good looking and has that same 'Wow' factor going for it.
5 its got four way pocket clip options.
6 the S30V blade has been very good performance wise and given very little trouble.
7 taking this folder apart to replace parts or clean it is as easy as field stripping anything else used for the Military. Its a breeze unlike the Tyrade is probably going to be by comparison.
STR
