- Jul 30, 2016
Hello,
please take a look at the attached drawing below. It's approximately 1 inch wide round blade of 0.06 inch thickness . I would need to create it from damasteel. Can you advice me on how to go about creating this:
Firstly, I have an idea of shaping the blade before heat treatment and leaving 0.015 inch blade edge before final sharpening after heat treat, would this work well?
Another method would be to just cut the U shape and not shape the blade at all, then heat treat and grind the shape out only after heat treatment. But I wonder if 0.06 inches is too thick to grind to razor sharp edge of 15 degrees after heat treatment?
Any other suggestions on how to do it properly?
