Heber, the 12" AK I got is pretty pointy (also the way I like them). My KNN Kobra is pointy, but not as much so as some I've seen. My Durba WWII has more of a blunt "bull nose", kinda like a skinning knife. Next time I order a HI khuk I'm gonna ask uncle to dig me up one that has a good point for thrusting. About the photo- my computer at home is dead and my current employer doesn't appreciate khuks enough to let me bring them to work and photo. If you want to etch your blade it's real easy 1) COMPLETELY degrease the blade. I cleaned mine with hand dishwashing soap and hot water. Repeat a couple times. 2) While blade is still hot from the water, rub a half of a cut lime on the blade. Rub pretty hard and fast and kinda keep squeezing fresh juice out of the lime. after a while you will see the temper line or hamon appear, and the hard edge will turn dark. Wash off the lime juice with soap and water real well, and oil the blade to prevent it from rusting. 3) use a soft cloth and a very fine polishing compound (I use automotive paint rubbing compound) to remove the oxidation or patina from the blade. If you don't overdo it the hamon will remain and the oxidation will come off. You can repeat the above steps a couple of times to make the line more pronounced. Good luck, gotta sign off now, stevomiller
