uddeholm bandsaw steel and advice for beginners
Hello Blade forum members! I have recently been bitten by the knife crafting bug and have the urge to build knives. I have a relatively large sheet (2ftx3ft) of uddeholm wood bandsaw steel. I'm no metallurgist and so i'm wondering if it is a good steel to make knives with.
I have built 2 knives but only consider one to be a serious build. I used some extra uddeholm steel i had laying around and ended up with a 6 5/8in long Karambit knife. I followed some advice i read somewhere which basically said to triple normalize, triple harden, and triple temper with critical (non-magnetic) being the point in which the blade was removed from the furnace. My current furnace is a large tin can with the bottom half of a colghans propane tank in it surrounded by mud to insulate it. I have a stainless rectangle with a hole cut in it for the MAP gas blowtorch. The oil i used for quenching is Canola oil heated to 130F. I proceed to temper the blade in a toaster oven (temperature checked with a bbq thermometer) at 350-400F (in actuality the temperature fluctuated from 300-450F, although i would open the oven door once it got above 410F until it went back down. At this time i was unaware of the brass rod test to check the tempering job.
I am pretty sure i did something that made one of you cringe but it's only my first time. I have some limited funds and am planning on picking up some 1095 Carbon steel as well as some 5160 spring steel for future blades as well as making a quenching tray instead of using a large tine can. Any advice and tips are welcome :p thank you in advance.
The Uddeholm wood bandsaw steel is likely 15N20, 1070-75 with nickel added. I use it for damascus, but prefer a higher carbon steel for my mono steel blades. W2 being at the top of my list.
No need to triple quench or temper. Quench once, temper twice. 300-450 is too large a swing for your tempering oven, but in reality it will probably get the job done, just not the best way to do it.
I use a lot of 15n20 and really like it. It's easy to heat treat, and is quite tough. Yes, higher carbon can get you more performance, if you have the equipment to deal with, but you aren't there yet. I have a kiln now and have a wide variety of steel to choose from and still use 15n20 just because it performs well, especially in thin blades.
The Count's Standard Reply to New Knifemakers V34
The answer to a young student is different than a retired machinist
With members worldwide, you may have a local supplier, hammerin or neighbour.
Join our community;fill out your profile with location (Country, State, City), age, education, employment and hobbies so we get a sense of where and who you are.
Look at the threads at the top of the page.
The basics in the simplest terms
Absolute Cheapskate Way to Start Making Knives-Printable PDF
http://www.2shared.com/document/hk4wQruA/Absolute_Cheapskate_Way_to_Sta.html
http://www.scribd.com/doc/3622507/Jones-Scott-Jonesy-Absolute-Cheapskate-Way-to-Start-Making-Knives
Web Tutorials
Detailed instructions http://www.bladeforums.com/forums/showthread.php?t=694673
The Things I Advise New Knife Makers Against-Printable PDF http://www.mediafire.com/?8og1ix21j9dcz4n
Handle Tutorial - Nick Wheeler-PDF http://www.mediafire.com/?02ra4do6xyzayeq
http://www4.gvsu.edu/triert/cache/articles/nw1/scales1.htm
http://www.bladeforums.com/forums/s...Wheeler-s-Steel-*-Stuck-in-the-metal-with-you
http://www.bladeforums.com/forums/showthread.php/956343-Damascus-integral-tag-along
Bob Egnath how to http://www.engnath.com/manframe.htm
Books
A list of books and videos http://www.bladeforums.com/forums/showpost.php?p=9435307&postcount=43
BladeForums - E-books or Google books http://www.bladeforums.com/forums/showthread.php?t=603203
Books I like:
David Boye-Step by Step Knifemaking
Tim McCreight-Custom Knifemaking: 10 Projects from a Master Craftsman
Clear, well organized, available and inexpensive.
Knife Design:
Think thin. Forget swords, saw-tooth spines, guthooks, crazy grinds and folders for your first knife.
Look at hundreds of photos
Start with a drawing and post it, we love photos.
French curves, graph paper and an eraser are vital tools.
http://3.bp.blogspot.com/_bHFtVNs9tWA/TEj5Quiq1ZI/AAAAAAAAAI0/rn2EoHoXpVc/s1600/The+French+Curve.jpg
http://www.bladeforums.com/forums/showthread.php/1147466-How?p=13120810#post13120810
Then a cardboard cutout template & with handles, pins and such.
Use playdough to shape a comfortable handle, good handles are not flat.
How to post a photo
http://www.bladeforums.com/forums/s...AL-Displaying-your-photographs-on-BladeForums
Google books thread for Lloyd Harding drawings, Loveless book & Bob Engnath Patterns. http://www.bladeforums.com/forums/showthread.php?t=603203
Bob Engnath Patterns in a PDF http://www.mediafire.com/?qgx7yebn77n77qx
Forging Books:
Lorelei Sims-The Backyard Blacksmith - A modern book with colour photos - forging - no knifemaking.
Jim Hrisoulas
The Complete Bladesmith: Forging Your Way to Perfection
The Pattern-Welded Blade: Artistry in Iron
The Master Bladesmith: Advanced Studies in Steel
Machine Shop Basics -Books:
Elementary Machine Shop Practice-Printable PDF Http://www.archive.org/download/elementarymachin00palmrich/elementarymachin00palmrich.pdf
The Complete Practical Machinist-Printable -1885-PDF http://ia700309.us.archive.org/6/items/completepractic00rosegoog/completepractic00rosegoog.pdf
Right Click and save
The $50 knife Shop-not recommended
This book has a great title, but is NOT gospel. It confused me for a long time.
Forging is NOT necessary; file and grind to create a knife (stock removal)
Forget the Goop Quench BS
Back when they used whale oil, it was still liquid oil.
Use a commercial quench oil & match oil speed to the steel type;
Grocery store canola oil works for some steels like 1084.
Junkyard steel requires skill and experience to identify and heat treat it properly.
Forget Lawnmower blades and railroad spikes, start with a new known steel.
Good heat treating needs accurate temperature control and full quench.
Proper steel like 1084FG from Aldo is inexpensive and quench in Canola.
Cable damascus is an advanced project has no place in a beginner’s book.
The grinders are the best thing about this book, but 2x72” belt grinders plans are now free on the web.
Videos
Don't be this guy
http://www.youtube.com/watch?v=gEOTtslHARQ
Heat Treating Basics Video-downloadable
Right click and save this. Watch it once a day for 10 days. http://www.archive.org/download/gov.ntis.ava08799vnb1/ava08799vnb1_512kb.mp4
Safety-video
Right click and save this. Watch it once a day for 10 days. http://www.howtomakeaknife.net/FreeStuff/SafetyVideo.wmv
Many knifemaking videos are available, some better than others.
The best beginner videos I have seen:
“Steve Johnson-Making a Sub-Hilt Fighter”
"Ed Caffrey - Basic Bladesmithing-Full DVD-ISO"
“Custom Knife Sheaths -Chuck Burrows - Wild Rose”
-(Paul Long has 2 videos, his sheath work & videos are fantastic, but more advanced-with inlays, tooling and machine stitching)
Green Pete's Free Video
Making a Mora bushcraft knife, stock removal, hand tools, neo tribal / unplugged heat treat.
Use a piece of known steel, not a file. This as an example of doing it by hand with few tools.
"Green Pete" posted it free.
Be sure to look at the other titles I mentioned too - spend some time searching.
Greenpete Knifemaking Basics-on TPB
http://thepiratebay.org/torrent/499...femaking_Basics_-_Make_a_Mora_Bushcraft_Knife
How to download that video
http://www.utorrent.com/help/guides/beginners-guide
Videos for rent,read the reviews, Some are good, some bad, expect to wait months
http://smartflix.com/store/category/9/Knifemaking
Draw Filing Demonstration
YouTube video -Draw Filing-for a flat finish http://www.youtube.com/watch?v=Dec78RQsokw
Nick Wheeler- Hand sanding 101 https://www.youtube.com/watch?v=4I4x4QLpfnk
Steel
The “welding steel” at Home Depot / Lowes is useless for knives.
Forget about lawnmower blades ,files, railroad spikes and other unknown junkyard steels.
For the work involved, it is very cheap to buy and use a known good steel.
If you send out for heat treating, you can use
Oil quenched O1, 1095, 1084
Or air quenched A2, CM154, ATS34, CPM154, 440C, plus many others.
For heat treating yourself with minimal equipment, find Eutectoid steel and quench in Canola oil.
1084FG sold by Aldo Bruno is formulated for Knifemaking, Cheap & made for DIY heat-treat.
http://njsteelbaron.com/
Phone # 862-203-8160
Suppliers List
http://www.bladeforums.com/forums/showthread.php?t=699736
Heat Treating
http://www.bladeforums.com/forums/showpost.php?p=9143684&postcount=7
You can send blades out for heat treating at $10 or $15 per blade for perfect results.
Air Hardening Stainless Steel Only
Buck Pau Bos -Be sure to check the Shipping and Price tabs.
http://www.buckknives.com/index.cfm?event=bio.paulBos#
http://www.texasknife.com/vcom/privacy.php#services
Oil Hardening Carbon Steels and Air Hardening Stainless Steel
http://www.petersheattreat.com/cutlery.html
http://www.knifemaker.ca/ (Canadian)
FAQ's
http://www.hypefreeblades.com/faq.html
1095 is good carbon steel, but a bad choice for a beginner with limited equipment.
1095 is "Hypereutectioid" and needs precise temperature control and proper fast quench oil Like Parks 50 or Houghton K
Kevin Cashen - 1095 - hypereutectoid steel
http://www.bladeforums.com/forums/showthread.php/673173-Working-the-three-steel-types
If you are sending one or 2 knives out for heat treatment, use 154-CM or CPM-154 CPM-s35vn Elmax, and ship it out to TKS -Texas Knifemaker Supply
It's the cheapest way to do 1 or 2 due to minimum charges.
Quenchants for Oil hardening steel
Forget the Goop Quench and Motor oil.
Use commercial quench oil & match oil speed to the steel type;
The best explanation and classification oil speeds I've seen
http://knifedogs.com/showthread.php?28197-Hardening-II-Quenching
Grocery store canola oil works well enough for your first knife-if you use the right steel like 1084
Brine and water are cheap, and technically correct for "water hardening" steels W1 and 1095 but a fast oil like Parks 50 or Houghton Houghto Quench K are less likely to give you broken blades
If you use water or brine, expect a "tink" and a cracked blade
Don't quench in a plastic pail of oil
Glue – Epoxy
Use new slow setting 30 min to 1 hour, high strength epoxy to attach blades to handles and seal out moisture.
Slow epoxy is stronger and gives you time to work with it.
Surface Prep is vital, drill tang holes/ grind a hollow, roughen the surfaces with abrasive or blasting is best.
Ensure the surface is clean and no oil including fingerprints.
Use Acetone & Alcohol, or Blasting.
Don't over clamp it A “glue starved joint” is weak when all the adhesive is squeezed out.
Brownell's Acraglas
West Systems G Flex
JB Weld-leaves a grey line
Grinder / Tools
Hand Tools
You can do it all by hand with files and abrasive cloth like the Green Pete video.
Just use 1084 instead of a file.
spheroid annealed steel is butter soft to file.
Stacy - 10 Tools
http://www.bladeforums.com/forums/showthread.php/1049666-Ten-Tools?p=11983527#post11983527
Examples of filing jigs
http://www.flemingknives.com/imagesPrime/FileStation/KPicB007.jpg
Http://farm9.staticflickr.com/8486/8152684286_312b9fc8da_b.jpg
http://www.youtube.com/watch?v=r9iNDRwwBQQ#t=330
Grinders
A professional three or four wheel 2x72 is worth it
In my opinion, variable speed and a small wheel attachment are essential on a good grinder.
You can almost always improve tracking with more belt tension. It needs to be way tighter than you first think.
Entry Level Grinders
Sears Craftsman 2x42 belt grinder
Low Speed Modification Craftsman 2x42 belt grinder http://www.youtube.com/watch?v=2qfYT_m2Tw0
Commercial Production 2 x 72” Belt Grinder Reviews
http://www.prometheanknives.com/shop-techniques-3/grinders
DIY 2 x 72” Belt Grinders
KMG Clone Free Plans
http://www.metalwebnews.com/manuals/knife-grinder.pdf
NWG No Weld Grinder-buy plans
http://usaknifemaker.com/plans-for-the-no-weld-grinder-sander-nearly-50-pages.html
EERF Grinder (EERF =“Free” backwards)
http://www.wilmontgrinders.com/Pages/EERFGrinder.aspx
http://blindhogg.com/blueprints.html
Buy the kit
http://polarbearforge.com/grinder_kit.html
What Belts to buy?
http://usaknifemaker.com/abrasive-belt-basics-what-kind-should-i-buy.html
VFD Variable Speed made simple
Step pulleys are not as cheap as you may think
Maska steel pulleys are good plus shaft, bearings, belt
It all adds up to about 1/2 the price of a KBAC-27D
I like direct drive with no belts using a VFD and 3 phase motor for about $200 over the price of the step pulleys with finer control.
NEMA 1 VFD’s are designed to keep your fingers out and the metallic dust intrusion will smoke it.
Motor
3 phase 220v 1.5 HP motor, TEFC, frame 56 or 56C,
RPM is up to you some use1700 RPM at double speed.
Make sure it has a footed base for the KMG and NWG, or a C flange face mount for Bader, Bee, Wilton and GIB styles.
I get them on ebay, even with paying $100 for shipping to Canada I save $ on used motors
The 1.5 HP combination is the most common
It allows you to plug into any 110vac, 15 amp outlet.
A 2 HP motor requires a 220vac input.
VFD
KBAC-27D
http://www.kbelectronics.com/Variable_Speed_AC_Drives_Inverters/AC_Drives_NEMA_4X.html
http://www.kbelectronics.com/manuals/kbda_manual.pdf
Use the Distributor Locator to find a local source, online sources may be cheaper.
There are cheaper units, but the only VFD I have found that runs a 1.5 HP motor on a 110v 15 amp input is the KBAC-27D
It is NEMA 4, sealed from metal dust
Good community and company support, manuals, hook-up diagrams, photos and settings.
If you buy a bargain vfd, you're stuck with a chinglish manual and ridiculous programming.
I like that I can buy it in person from a local distributor in Canada.
Travis W reports running a 2 HP on a 110v circuit, but I haven’t tried it.
Hookup is simple
http://www.beaumontmetalworks.com/VS-setup.html
Safety Equipment
Protect your -Eyes, Ears, Fingers, and Lungs – remove jewellery and use safety gear.
Respirators
Chronic lung disease and cancer really suck the joy out of life.
If you can't breathe, nothing else matters.
Wearing a mask and glasses on the top of your head doesn't count.
The minimum I would consider are silicone half masks with a P100 Filter
3M 7500
http://multimedia.3m.com/mws/mediaw...Ox_Uev7qe17zHvTSevTSeSSSSSS--&fn=CH7500FP.pdf
and North 7700
http://www.amazon.com/North-Safety-770030L-Silicone-Respirator/dp/B002C08YCW
http://www.amazon.com/North-7580P100-P100-Particulate-Cartridge/dp/B000UH6PSE/ref=pd_bxgy_hi_img_b.
Use a VOC & P100 combo cartridge for acetone and glue fumes.
Prefilters can snap over the main filter for longer life.
There are 3 sizes get fitted in person
Shave, also test the every time.
For beards
3M PAPR
Resp-O-Rator
3m Breathe Easy
Trend Airshield Pro
Air Cap II
Search
This Google page searches BF well.
http://www.google.com/cse/home?cx=011197018607028182644:qfobr3dlcra
Get rich making knives ?
http://www.bladeforums.com/forums/s...knife-making-worth-it?p=11980504#post11980504
A shop visit
http://www.bladeforums.com/forums/showthread.php/1166688-How-to-get-a-shop-invite
V34 March 23, 2014 NW WIP
a real wealth of information. thank you all so much! i'm actually about to head out and see if i can find a cheap toaster/convection oven and a hairdryer to canabalize for parts to (hopefully) make a more accurate tempering oven. that should work for the moment. i'll have to read through all the replies a few more times to get it all.
Greetings to all people on this forum. I need some help. Can someone give me direct link about clay coating knives. I want to make knife (dagger) from saw blade. Thank you very much
just curious how accurate does a tempering oven need to be? i picked up one at the goodwill for $15 and it seem to hold between 385-400 consistently. (checked with a bbq thermometer) is this accurate enough or would you still recommend the modification parts
You're best bet is to use your kitchen oven (with clean blades and a good oven thermometer).
nocke,
Welcome to Shop Talk. Filling out your profile will help us help you. Knowing your age, location, hobbies, and occupation helps a lot.
Please start a new thread with your question. Hijacking a thread is not polite ( it is not allowed, actually). Hijacking two threads with the same request is very bad etiquette.
This search engine will find your request:
https://www.google.com/cse/home?cx=0...44:qfobr3dlcra
Others - Please don't respond here, wait for his new thread.
parents don't like to run the big oven unless something else is in there so i'm kinda out of luck in that aspect. does anyone have a list of parts to do the conversion from toaster oven to tempering oven? i was looking at this kit maybe http://m.ebay.com/itm?itemId=121094869999
is this even the right stuff?
Those parts will work. There is a thread in the stickys about doing the conversion.
I have little knowledge about blade making and the list of books/videos/links posted above would be very helpful. Thanks for posting.
The thing about using a saw blade is your guessing about what steel it is.30 years ago I met Jerry Busse he told me if you don't know what kind of steel it is your guessing on how to heat treat it.So I got away from saw blades.and bought from a steel supplier.Takes out all the guess work. my friend made some knives out of saw blades. After heat treat they would'nt hold an edge very long .Alot of lost time. If you sell one and i t does'nt perform your reputation can and will get trashed after a while.
