I drive one daily. Since I have no idea what "double clutching" is, I assume it's not necessary. ???is the transmission of a standard 2.5 ton army truck synchronized or do you have to double clutch?
Ours are mostly '69 - '69 models. Don't know the rebuild dates.Anything built in the eightys and newer should be but if your looking at older ones they probably aren't.
You are correct.R 2 5
1 3 4
I think that's right. It's been awhile.
On the positive side, they are very durable, cheap, and have great clearance and off-road capabilities. On the negative side they are butt-ugly, uncomfortable, slow, unsafe, death traps. Not to mention that diesel is now $5 gallon...someday I want one.
Thanks for the explanation. No, you don't have to double-clutch a military surplus duece-and-a-half. Maybe you can if you want to?Double clutching is when you let the clutch out between gear shifts while the shifter is in neutral to keep the innards spinning.
Very cool, I like that.
R 2 5
1 3 4
That layout is called a dog-leg transmission. It is easier for slower speeds since you only need 1st gear to start up and then the rest is going from 2 to 3 or vice versa.
I'm not sure what the Army uses those for. Communications?Cool. Is that a radio truck?
