Ultimate Fighter review; pix
Through the generosity of a well-respected forum member, I came into possession of a Himalayan Imports "Ultimate Fighter" (UF) last week.
Just want to point out some stats on it that may be of use to our resident knife-designers since this is an unusual blade, to say the least.
There have been several designs based on this model; seems the kamis are playing with it themselves. This particular one:
Length: 21" to tang-bolt, 20.5" to buttcap (blade tip to end overall)
Weight: 2 lbs, 14.8 oz.- yes, that's 46.8 ozs.
Thickness: .55 spine thickness (!) at bolster, .50 at curve, .30 at tip.
By comparision, my 20" AK weighs in at 2 lbs, 1.5 oz. and a YCS (from the first batch) weighs 2 lbs, 3.6 oz.
My 25" Malla weighs 2 lbs, 7.6 oz. and the 25" Gelbu Special is 2 lbs, .07 oz. At one time I considered those large, heavy knives.
You can draw your own conclusions, but this thing looks medieval and is built like a bear. The only way to carry it is baldric-style, which is pictured. Paul Bunyan couldn't carry it on his belt.
In this way it's possible to carry the UF cross-draw.
1. Think of it as an axe. It can be used one-handed, if you've the strength. It is large enough, however, to permit a two-handed hold and swung like a conventional axe.
2. Think of it as a halbred head. Though it has a wicked sharp false edge, that can be seen as a weight-saving measure in a half-inch thick blade.
3. Think of it as a cutlass (and sword-breaker). It can be used to thrust, again, if you've the strength.
It's the most impressive HI I've seen; a "10-10" rig, as UB would say. The only one I've got with a half-inch blade. The sheath is really wide, but that keeps it flat on your side. The blade has been etched, but the etching is partly scrubbed off with a green Scotch-Brite. It seems like a typical quenching line.
My buddy, Capt. Anibal Ungaro, was "nice" enough to model it today. He was sober and not PO'd, which made me feel somewhat safe.
I'm not drawing any conclusions; just throwing out the stats and pix.
What do you think of the H.I. UF?
Mike
It is a valid question. :p I'd like to go after a decent-sized tree.
I'm semi-laid up with a knee injury; got nothing around to chop. No trees on my property since the hurricane.
Mike
While not a first choice in a fencing competition or a stiletto duel, the UF would be in its element when a giant squid tentacle comes over the deck rail...
and as a crash axe, it surely could bust down a door. Or a wall.
Mike
Nice, though with the false edge on the spine, I would be somewhat worried about chopping / slashing because of the lack of mass on the spine.
Batoning it is out of the question. :D
Ultimately (no pun) it's an interesting axe/knife/sword hybrid design.
Mike
Slick rig...I would think about replacing the standard nut with an acorn nut. That would give the handle a nice finish, IMO.
Nice blade and pictures, thank you
Very nice, Mike, and good pics. I have one of these, the first engraved one I believe, but the handle on yours is much, much nicer. I also like the looks of the plain blade. Mine is almost the exact same specs as yours.
The only thing I would change on it is the rear nut. By turning it down and rounding it and then heating it and treating with cold blue, it looks a lot nicer, IMHO.
Here's a couple of pics I sent to Dick last year after I changed the nut:
attachment.php
attachment.php
Norm
Thanks, Norm. Would like to get a round or decorative nut for it... and I wonder how a longer, two-handed polearm-type handle would do on it?
the kamis must think we're all 7' tall to swing that one-handed. But like the Viking told Banderas in "The 13th Warrior," when he complained about his sword- "Grow stronger." :p Play with the UF for a while and you feel like you can whittle with a 20" AK.
Mike
Would like to get a round or decorative nut for it... ?
Mike
Mike I don't know and rather doubt that Lowes or Home Depot would have any "acorn, or cap, nuts" that size but I'll bet you can find the right size online.
You'll probably have to buy more than one just to be able to get any at all but they sometimes come packaged in sets of six or eight depending on size.
This site has acorn nuts...
Here is the page result from Googleing, "acorn nut.:thumbup: ;) :cool: :D
I've been curious about this blade for a long time, and I'm glad to see it reviewed.
It was a forumite/customer idea. You can imagine all the ideas Yangdu has submitted to her. Some special orders we at HI forum never see, some we do.
When I learned of this blade I knew anyone who knew anything about 'knife fighting', would object to the weight. Yet, "Ultimate Fighter" is what the client called it. Why?
I'm still of the same opinion now as when I first knew of UF's existence; That it is "Ultimate" in the sense that it is heavier and tougher than anything that might reasonably be thrown against it. Yes, it can break things. That a fellow might be breathing through 12 different holes by an opponent with a lighter, faster blade by the time UF is at arms is....will remain a mystery that only the creator could answer. I guess you could laugh at it as a creation a 12 year old might concoct; "Let's make it the biggest, and thickest, and toughest blade of all time!" Then they go back to trading their MBA playing cards and Spiderman comics. But looking at the photo, and knowing the weight length range balances of HI blades fairly well, I gotta say: I like it.
It's a hell of a lot better than the Jungle Killer I reviewed here about a year ago. (mostly a sharpened peice of spring steel with a upturned point on it)
Anyway, like the big old Garand that goes Boom every time, I'll bet the UF can chunk away trees, and even break a blade thrust at it, if the user is strong enough to handle it, every time.
Maybe Spiderman could use a blade....
munk
