Sorry to blaspheme, as you know I'm a Seb-lover for life, but:
CRK, NOTHIN' BUT LOVE FOR YA, BUT WTF?
Why, oh why, are screws coming loose? Why are people talking about Loc-Tite? You haven't secretly shifted your manufacturing overseas and not told anyone, have you?
___________________________________________________
Now that that's off my chest, Joebobx, did the screw actually back out, or did the clip itself, still screwed in, rotate in the clip cutout? If the screw backed out, I would simply tighten it back down with some torque on the Allen wrench; I would not use Loc-Tite, as I've heard of even the blue variety causing enough hold that the Allen wrench strips out the head of the clip screw when trying to remove the clip again down the road. The 303 screw will gall enough with the ti threads to not back out again, thus making Loc-Tite unnecesary. If the clip rotated in the clip cutout, then remove your clip (which is titanium, to answer your question), apply a less-than-paper-thin coating of epoxy or polyurethane glue only to the portion of the clip that sits in the clip cutout on the handle, allow to completely dry or cure before re-assembling, then re-assemble. The "gumminess" created by the epoxy or glue will keep the clip from moving inside the clip cutout. I actually do this on all my Seb's, to prevent clip movement in the clip cutout from happening in the first place. If you EDC your Seb, after a number of years, that movement tends to happen (at least to me).
My EDC small Seb's clip started moving around inside the cutout, and I did the epoxy trick and you could probably stand on the clip now without it moving at all.
To answer your other question, the ti CRK clips are quite bending and forgiving (considerably moreso than stainless clips such as BM clips), but do scratch easily, as does the ti finish of the knife. To increase tension if stock tension is not enough, or if you snag something and bend it outward, take your clip off (preferably before you do the epoxy trick aforementioned, if that was indeed the problem), tape up the end with the screwhole to prevent scratching, put the taped end in a vise or locking pliers, and bend inward to increase tension. It works like a charm on the newer CRK clips, which are a lighter (thinner) gauge ti than the older clips.
Good luck to you, God Bless, and thank you for your service to our country!
Professor.
