- Apr 19, 2007
OK, this was odd, so I'm seeing if anyone's come across this. I've had a few Sebs & 1 Umnum. The Umnum, which I've had since almost the beginning of the yr, has pretty much replaced my lg. Seb. However, I do like having & carrying my small Seb when I don't want the larger knife.
So, I have a small classic Seb along with the Umnum. The Umnum's clip was pretty snug, while the Sebs wasn't. Since I like using a lanyard on the small Seb, I don't mind a snug clip on it, so I swapped clips.
The small Seb seemed fine & the lock-bar might've moved just a tiny bit more toward the center. However, I immediately noticed the Umnum's lock-up was definitely lighter. In fact, if I gently open the blade, you can actually tap on the blade spine & it'll close. Has anyone noticed this? I'm guessing it's because of the ceramic ball. Since the lock face isn't a relatively flat lock-bar, the ceramic ball might slide off a bit. Now, if I thumb it open with decent force, lock-up's fine, but I just noticed that a soft opening won't fully open it.
Has anyone noticed this or is this mainly because of the clip? As I said, it only happened when I swapped clips & the clip that I put on it, doesn't rest against the lock-bar like the other one does.
