- Dec 26, 2008
Is there any reason to adjust or disassemble my Umnumzaan? If so do I need a special tool?
thanks
thanks
I just bought an umnumzaan tanto second hand. Took it apart last night and the lube is gone on the brass washers (correct part name?). The lube is gummed and right on the outside circumference of them. It's amazing how smooth the knife functioned with the lube the way it is. I will be calling tomorrow to order some. I'm curious to see the function after a lube job.
I wouldn't take the knife apart unless cleaning or adjustment is needed. Then use the Loc-Tite. I didn't use the Loc-Tite and reassembled the knife. After a few openings the pivot loosened and the blade was touching the side. I don't plan on carrying the knife until I get it lubed properly, that's why I didn't use Loc-Tite on reassembly.
Will do. I was going by the lube. It's more of a gum consistency mixed with gunk and lint. I didn't order any lube, maybe I'll have time tomorrow.
We all loved the syringe but CRK’s vendor could no longer source them -not sure why. We waited for about a month to see if the situation would change (you may have noticed a lube shortage a bit ago) but it didn’t. In order to supply grease to customers we were forced to go with the tube. I’ve no idea if the syringe will come back but we would like it to. Just a note, the quantity is the same. It is just the container that has changed.
