- Aug 28, 2020
I've mentioned in https://www.bladeforums.com/threads/another-umnumzaan-joins-the-fray.1748148/ that my 'zaan was extremely gritty and exceedingly hard to open (painful with both hands) until broken in.
From multiple threads i've read while preparing for purchase, it seems like there's been a lot of sample-to-sample variation both over the years and from within same batches - some people had smooth Umnumzaans straight out of the box, some broke in in the first hour of use, some had issues for weeks until either persisting through it or sending it back to CRK.
So here's my theory, and i apologize if this was covered before - it's the damned ball. It's an inherent source of tolerance issues. What most people call "tight tolerances" is actuall the fit (tightness of fit and allowance). Tolerance is the variation from sample to sample. For the most part, CRK knives exhibit tight tolerances wherever it makes sense, and rely on other classical techniques of ensuring alingment and fit, like self-centering screws / countersinks.
The ball, is the one exception.
This is what the crimping looks like up close:
Does this look like an inherently repeatable process?
It doesn't to me. A bit more force on one side vs. the other and you'll end up with a very slightly differently aligned ball.
Here's the track it inscribed in my 'zaan's blade:
If you look closely, you'll notice it's slightly off center from the hole. This causes the lockbar to flex sideways slightly when the knife closes and the ball falls into the detent hole, requiring a slight additional force to kick the blade out of the detent on this particular sample.
This is one source of the variation, but there's another one.
The ceramic balls are not perfectly spherical (not just in 'zaan's case).
In fact, look closely at mine:
It's a bit hard to see, but make sure to switch the video to HD and pause occasionally. My ball has a ridge right smack dab in the middle of the interface with the blade. This causes it to bite deeper into the blade when locking, but more importantly in this particular case, when opening and closing the blade too (since the slight ridge goes all the way around).
My bet is - on a 'zaan with a more... uh... spherical sphere... the friction and break-in period would be much faster than on mine.
So there ya go.
What do you think, am i completely off base, or is there something to it?
So there ya go.
