Gentlemen,
First let me say that we want you to be happy with your purchases. We will be glad to take a look at your knives and effect any repairs needed. I do, however understand that you are FAR away from the USA, and don't want to send in the knife unless needed, so...
Blades being centered. Guys, we do everything we can to ensure that the blade doesn't rub the frames by being off center. This can be influenced by several things, mainly by ensuring that the blade is straight, that there is nothing stuck under the blade washers[a tiny spec of foreign matter can cause big problems], that the frames are flat and parallel, and that the pivot screw is tightened sufficently. That is usually where the confusion starts. If you tighten the pivot screw down, the blade may center, but the "action of the knife" may be too slow. We cannot ensure that the blades fall EXACTLY down the middle when you have the knife adjusted to a looser or "faster" setting.
To surmize, we will be glad to warranty any of our knives if you are dissatisfied, but we cannot garantee that every blade will fall EXACTLY down the middle in the closed position. If it is rubbing on the frame, and the pivot is reasonalbly tight, there is a definite problem, and we of course will take care of that also. The DOMINATOR in my pocket is "slightly" off center[tip toward the non locking side], and its just fine with me.
Regarding lock engagement. 20% of the lockbar engaging on a new knife is fine, as long and the lock is not slipping any. The engagement will wear in a bit, and give you a very long lock life. If the lock is slipping at all, then there is a problem and we will be glad to take care of it ASAP!
Kevtan,
Regarding your edge bevels, they should not be "rough"....we do not mirror polish them, but they are "buff polished" after setting the bevels. Again, if you you are unhappy, we will be glad to address it.
I'm sorry if it sounds like I'm beig vague, but these issues are a bit of a judgement call, and its hard to tell without seeing the knives. I know this puts you in a tough spot, being so far away, but rest assured, that we will stand behind our products 100%.
If you want to return the knives, please contact customer service @
customerservice@camillusknives.com
Thanks for being a customer!
