Uncle Bill:
What can you tell me about the Gelbu Special? I couldn't fine the weight at the shopping site. I think it would be a pretty good weapon.
Figure about 1.5 pounds for 18 inch and 2 pounds for 21 inch. For whatever this might be worth -- based on 6 years service in the Assam Rifles Pala said if he were in charge of the Gorkhas serving in the Indian Army the Gelbu Special would be the standard issue. He has a very high regard for this khukuri. And, not because it is named after son, Gelbu. It is actually a BirGorkha version of an old, tried and proven village model.
Thank you Uncle Bill, I was sure that was the case with the Gelbu. I like the looks of the 18" model. I'll let you know when I have enough to get one. If any one knows what would be a very good blade for all around uses, it should be Pala. I can't think of a better recommendation. Thanks again.:) :)
You need your money pretty quick. That sure would be a hell of a birthday present though wouldn't it?:D
You need your money pretty quick. That sure would be a hell of a birthday present though wouldn't it?:D It looks like the new servers are working overtime.:)
Pappy, check your mail. Sounds like your birthday is close to mine
Pappy needs the improved snake killer.
If you were a snake, would you want to be in Pappy's yard?
munk
If I lived around Pappy's neighborhood I'd think of carrying a Hungarian axe. A smaller ( 6-8" edged head ) on a 4 foot haft. Better yet, a short light 20 ga.
The Gelbu Special is quick and snappy compared to the Siru I have. One thing though, is there's not much belly, so it's a little less effective at chopping hard wood. The handle is a bit skinnier too, for what it's worth. The sweet spot seems a little smaller than some khuks too. The Chitlangi is another one to put on your list also. Pretty similar to the Gelbu, but just enough belly to have a big sweet spot and handle the hard wood. And theres that great Chainpuri handle.
Rusty,
Friend of mine lives in the Dakotas, carries one of these as his snake gun. http://www.thunder5.com/
Interesting little 410.
TC
I gave a buddy an 18" GS by Kesar.
I think that it's primary attraction as a field knife would be the weight - not a ton of weight to carry around, and very quick if pressed into combat. It would do a good job on green wood and thinner stuff, but it's not as good a chopper as most other HI khuks. That said, it will still beat the tar out of a Kabar or most other straight knives. If you have good technique- a fast swing with wrist snap and perfect contact- it will probably chop pretty well even on hard wood.
Definitely on the short buy list for me, though I haven't been able to handle an 18" chitlangi for comparison purposes.
I really like the 18" GS. Light, quick, I think it's really well-balanced especially for directional changes.
Wouldn't think you'd be disappointed with this one for snakes or ....others.
Pappy,
18" GS on deuce gear as the primary all-around user. Could go to a 18" WW II, UBE, or lighter AK depending on specifics.
S/F, Mike
Thunderchyld: seldom get to Reno to hit the stores, but haven't seen those in maybe 3 years. I guess it would work shooting the snake twice and waiting to see if it moves before edging up for a final shot. Out here I still like a 41 with rolled down windows from the inside of the truck. Then drive over it a couple times to make sure.
Before I forget, did I mention that I don't like snakes?
Me either!!!!:)
Younger Bro what are you doing up so early, or late, depending upon your POV.;)
