Off Topic Understanding Sword Balance: Distal Taper, Point of Balance and Center of Percussion
Everest Forge
Dealer / Materials Provider
Understanding Sword Balance: Distal Taper, Point of Balance and Center of Percussion​
A well-made sword is not just about the look. It is about how it feels and performs in motion. Whether you are a martial artist, a collector, or simply interested in traditional weapons, learning about key sword design features like distal taper, point of balance, and center of percussion will help you better understand how real swords are forged and function.
These features directly affect how a sword handles, how it cuts, and how it transfers energy during use.
Sword balance diagram showing center of gravity, pivot points, and vibration nodes
A visual breakdown of sword balance, including center of gravity, blade node, hilt node, and pivot points – essential for functional design.
What is Distal Taper​
Distal taper refers to the gradual thinning of a blade’s spine from the base near the guard to the tip. This tapering affects how the sword moves and feels. It is not about how sharp the edge is, but about how thick the blade is from one side to the other.
Distal taper makes the blade lighter and more agile while keeping it strong near the hilt where it needs structural support.
For a video explanation, see Distal Taper in Swords – Scholagladiatoria (YouTube)
A sword without distal taper often feels heavy near the tip and is harder to control.
What is the Point of Balance (PoB)​
The point of balance is the spot along the sword where it naturally balances if you were to place it on your finger or a narrow support. It is usually measured from the guard moving forward toward the tip.
The point of balance helps determine how the sword feels in the hand. If it is close to the guard, the sword feels fast and nimble. If it is farther toward the blade, it feels heavier and delivers more force.
Most one-handed swords have a point of balance about 2 to 4 inches from the guard. Longer or heavier blades like sabers and Viking swords may have it 5 to 7 inches out.
Watch How Important is Point of Balance? – Scholagladiatoria (YouTube) for a detailed explanation.
What is the Center of Percussion (CoP)​
The center of percussion is often called the sweet spot of the blade. It is the place on the blade where a strike delivers maximum impact with minimal vibration in the hand. When you strike with this part of the blade, the energy goes into the target instead of back into your wrist.
The center of percussion is usually located about two-thirds of the way down the blade from the guard. It is different for each sword depending on the shape and balance of the design.
Watch Where is the Center of Percussion on a Sword? – Scholagladiatoria (YouTube) for a clear visual explanation.
How These Features Work Together​
Distal taper, point of balance, and center of percussion all influence how a sword performs. A sword with proper distal taper has better balance. The point of balance affects control and cutting power. The center of percussion is where you get the cleanest, most powerful strikes.
A good swordsmith uses all of these features to shape a functional weapon that feels right in motion and delivers real performance, not just looks.
Final Thoughts​
If you are serious about swords, understanding these three design elements will help you choose the right blade and appreciate its craftsmanship. Real swords are built for purpose. They are made to move well, strike cleanly, and feel natural in the hand.
At Everest Forge, our swords are hand-forged with these principles in mind. Each blade is balanced and tested for function, not just appearance. Whether you use it or collect it, you will feel the difference.
Final Thoughts​
All great points. However, the physique, physical strength, and training of the user also play vital parts. All beyond your fine depiction.
Not a sword per se but I have seen the "light in the eyes" when some folks handle a replica OKC-licensed Bagwell Hell's Belle Bowie knife.
Exactly same principles apply.
Richard F. Burton's The Book of the Sword (1884) is well worth reading. It has been reprinted and is available on the river company. Burton wrote an extensive explanation of how Wilkinson devised a method for determining the center of percussion based on the properties of a pendulum, as well as many other properties of edged weapons.
Vincent gets deep into the dynamics of handling, beyond the static numbers.
Peter Johnsson has been swordsmithing for 30 years or so. Along with Vincent, there have been a lot of videos beyond Matt and Schola.
Keeping all the math in mind, there are some mass distributions that work well, depending on use.
A four foot rapier and a four foot longsword are two fairly different beasts.
What I'm seeing a lot of this decade is trying to reinvent what swords handled like. (not that there's anything wrong with that) There are a good number of a new generation carrying on past discussions, in the form of their own pages.
Lots of articles here
Peter and Vincent used to hang out at myArmoury, which has been very quiet but Vincent had recently posted
