Someone is selling a larger pulley specifically for 9" bandsaws for $75 plus shipping, but my model is not mentioned. I suppose I'll look at adapting a step pulley as you suggest. Another thing I noticed is that used gear reducers can be had for around $40.It has already been said, but I will add to it, induction motors, which are locked to the line frequency, are not slowed by reducing voltage, they are slowed by reducing the line frequency which requires a variable frequency drive. In this application a step pulley reduction would probably be the best bet.
Do you want to slow down the saw to cut metal? I don't want to discourage you from trying to make that work with the saw you have, but the Harbor Freight Variable Speed bandsaw is not terribly expensive ($129) and you can probably find a coupon for 20% off.So, bad idea... What are some other ways to reduce speed? I've seen larger pulleys. What else is out there?
What's the point of all this ?
I had a bandsaw of that type.
I consider it ok for kydex cutting for sheaths.
Silk purse/sow's ear
The wheels are plastic
It has half the blade guides it needs and those are weak.
The whole thing is made of cheese, no rigidity
You won't get any metal cutting blades for it.
I would not spend a single dollar on trying to get it to do anything else.
I agree with the above, get the HF portaband.
Get the bi-metal blades for it, not the carbon.
You can get Milwalkee blade in any Home Depot
If you order online 25x at a time, you can get them for $6.50 each.
It will cut steel
10 Amp Deep Cut Variable-Speed Band Saw
Amazing deals on this 10Amp Deep Cut Variable Speed Band Saw at Harbor Freight. Quality tools & low prices.www.harborfreight.com
Many folks have these instead.
1 HP 4 in. x 6 in. Horizontal/Vertical Metal Cutting Band Saw
Amazing deals on this 4In X 6In Hor/Vert Metal Cutting Band Saw at Harbor Freight. Quality tools & low prices.www.harborfreight.com
I had two, paid full price for both and couldn't keep a blade on despite fiddling and adjusting
If you're on low $, I'd do my first 100 knives with a hacksaw and files, maybe add an angle grinder in there.
But if you try mods on that bandsaw you would be pissing away good money.
get the portableI'm investigating mods for the Ryobi BS901 because I inherited one. It needs several repairs due to being left to sit for several years: new tires, plastic knobs cracked, etc. My intent for this was to make cutting 1/8" steel quicker and easier. EZ Lock disks in my Dremel will work, but it takes a long time and is rather error prone. So I cut out something significantly larger than it needs to be and then I file it to shape. Given that I also want to use this bandsaw for cutting wood and the complications people have warned me about monkeying too much with this thing, I'll reserve it for wood use. I have been eyeing an angle grinder for doing things other than making knives, so that's on the table.
I'm having trouble telling which saw was the one that gave you trouble.
