- May 31, 2015
Hey everyone, I'm rather new here. I've been lurking for quite awhile, finally decided to join.
I've recently picked up an edge pro, and have been learning how to use it. On the most recent knife I've been sharpening, (browning Black Label), I've found that the factory bevel is uneven on one side. About one centimeter of the heel of the blade has a significantly steeper angle than the rest of the blade on the one side.
this is irritating, since I think I'll have to remove quite a bit of metal to even things out. My question is, is this normal? I've had already seen two blades with similarly steep angles on the heel of the blade. One was a Saber pairing knife, and the other was a Benchmade mini griptillian, although the griptillian was such a small area that I decided I could live with it. Is this something you see a lot, and how do you recommend dealing with it? Keep grinding, or let it go?
Thanks.
Thanks.
