I bought a Gayle Bradley from an online retailer this summer. When I went to sharpen it on the Wicked Edge for the first time a couple weeks ago I noticed the grind is off on one side. It makes using the WE a bit trickier because it doesn't sharpen evenly on both sides. Basically when I hold the knife with the blade vertical it looks slightly tilted to one side. I don't have a DSLR camera so unfortunately I can't get it much clearer than this:
If you look closely you can see that the grind on either side of the blade at the end of the choil is not evenly spaced between both sides. The bottom side is shorter than the one on the top in this photo:
Then I noticed that the grind on one side isn't in a straight line. It's actually cut lower on one side than on the other:
Compare how close the grind goes to the Spyderhole in that picture with this one. This grind is in a straight line and it's closer to the Spyderhole than on the other side:
Anyway, is this something that Spyderco would fix under warranty or are uneven grinds "cosmetic issues" that aren't covered? I'm going to keep and use the knife either way but having even grinds would make touchups on the Sharpmaker a bit easier.
