I've been having a problem with 1020/1095 damascus of late- I seem to be getting an uneven hardening which results in an uneven etch.
The affected areas tend to be concentrated in the thicker portions of a blade, and the final etch is much deeper there. These areas are occuring in only one material- i.e. the deeper etch is presumably in the 1095 and not the 1020.
At first I was hardening in a motor oil, so I switched to a #50 queching oil from Heatbath. I still had the uneven etches sometimes, although less severe. I then determined that I was quenching too high after more careful testing with a magnet. Still sometimes getting the unevenness I moved to a water quench (not brine; not heated) Again, I still sometimes get this result.
I should mention that the materials are 1020/1095, 100-400 layers. I immediately triple temper in an oven at 400 degrees for one hour each time after quenching. The unevenness is not due to surface grease prior to etching. The earliest, worst examples resulted in a hardening along the thin blade section of a single edged blade with the deeper etch (presumably unhardened) along the thicker spine.
It seems to me that the hardening is the problem- but I cannot eliminate a cause. Sometimes I get this exact result and sometimes the blades come out fine.
Any suggestions?
J.Loose
www.jloose.com
Any suggestions?
J.Loose
www.jloose.com
