airyq
- Nov 10, 2003
I have several slipjoints where the top of the tang (the part that you see looking down from the top when the knife is closed) is unfinished or partly unfinished, meaning that while the rest of the blade is mirror polished, the top of the tang is left rough and dark or there is a rough dark patch. Some times it looks like a raised seam running lengthwise on the top of the tang.
Strangely however, I do not see the same on the bottom part of the tang while the rounded end part of the tang is always finished smooth and polished.
The size of the patch, the roughness and the darkness varies from knife to knife.
While I do not expect the entire blade to be mirror polished, I would expect that at least the top of the tang to be finished smooth with a least a satin finish.
Two which are particularly obvious are a Queen whittler and a Schatt & Morgan stockman that I own. I was particularly disappointed with the Schatt & Morgan, even though it was just patches and not the entite top of the tang, as it was my first Schatt & Morgan and I was expecting perfection or close to it.
I am not trying to flame Queen but due to what I have read here about Queen, I had higher expectations. I have also encountered the same problem with other slipjoint makes as well but less so with Case. In Case knifes, while the tops of the tangs are not as well finished as the rest of the blade, it looks that at least some one tried to give it a grind and some polishing.
In contrast, "modern" knifes like Spyderco and Benchmade always have nicely finished tangs.
Function does not seem to be affected by this "flaw". Not an issue with a work knife but it is unsightly for a safe queen that will be picked up and scrutinised.
I am sure that you guys must have encountered this as well.
Would appreciate your views on:
1. whether this is normal and to be expected in a slipjoint?
2. is this a flaw in workmanship that would justify returning the knife?
