I found this very strange slipjoint when digging through some of my late grandfather's tools. I've never seen anything like, but then again I haven't been around that long. I was hoping maybe one of the old timers (or maybe "well seasoned knife aficionado" is a better term
) aroud here could help with ID.
At first I thought the little hook at the blade base was for prying or something, as it looks like a bottle opener. It was way too small though. After playing with the knife, I realized it was a locking mechanism. There is a loose sliding pin inside, mounted across a slot in each liner. When you close the knife tip down and give it a shake, the pin slides into the blade cutout, locking it shut. To open the knife, you flip it tip up (when closed), then give it a little shake, and press down on the blade and release. The blade is slightly spring loaded, and pops up out of the knife body slightly, to allow you to pinch the blade out into the open position.
At first when I found the knife, I was very confused about how to open it, becase there is no fingernail notch. This is actually a very novel mechanism, it operates a lot like those magnetic catches that you find on entertainment center doors, where you push in and the door pops out a little to you can grab the edge to open it. In this case though, it acts to lock the blade shut, as well as allowing the knife to be unfolded.
The only marking of any kind on the knife is "PAT NO." and some unreadable patent numbers beneath.
Kind of a neat "el cheapo" celluloid pattern on the scales, reminds me of a guitar pickguard.
Here's a view of the sliding pin inside the handle
This shows the blade in the closed and locked position
This is after you have pushed down and released the lock, with the blade sprung up in the ready to pinch position
