I've been using my Sharpmaker for about 6 months now. I have the UF stones but not the diamond ones yet. When I was getting to know the Sharpmaker I would use the sharpie trick every time and I still use it a lot. So here's what I noticed tonight while I was sharpening my DF2.
I was touching it up with the fine stones and started with the corners, as usual. I was in a different room tonight with different lighting. I noticed that after a few minutes I was getting "dings" on the edge that I was able to see with my naked eye. I use the JDavis one side then swap to the other side. I only do 10 - 15 strokes per side. I then go to alternating strokes with even less pressure. I do this on the corners then the flat side. I use very light pressure, keep the blade as vertical as possible and go pretty slow. I ended up pulling out the medium stones and fixing it with the flat sides. I just used the flat sides for all three sets of stones and it seemed to do fine.
I've seen posts where people have said that they just stop using the corners of the stones all together. Is this one of the reasons why? Also, any additional tips and tricks would be appreciated. I have done a lot of research on using it in the past, but this one stumps me.
Best,
Rhett
Best,
Rhett
